stock 383 oil pan 402 with windage tray #2170391
10/08/16 04:55 PM
10/08/16 04:55 PM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
do i need to get longer oil pan bolts and not use the factory bolts?i have no bolts at all right now. thanks
Re: stock 383 oil pan 402 with windage tray [Re: moparpro] #2170400
10/08/16 05:07 PM
10/08/16 05:07 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
With the 2nd gasket & tray, bolts may need to be 3/16" longer than if you just stuck the pan on. Proper bolts have captive washers, by memory the threads were maybe 1/2" - 3/4" long. I think there's a breakdown in the Archives somewhere with tightening torques.
Re: stock 383 oil pan 402 with windage tray [Re: moparpro] #2170407
10/08/16 05:27 PM
10/08/16 05:27 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Get a stud kit from 440 source. I used SCE gaskets and was super impressed with them.
Re: stock 383 oil pan 402 with windage tray [Re: moparpro] #2170561
10/08/16 09:22 PM
10/08/16 09:22 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Reproduction oil pan bolt set for big block Mopar worked perfect for me , including both the factory rear main seal retainer and Mancini Billet rear main seal Retainer when I screwed them in by hand , making sure they where not to long for each retainer and not bottoming out
Anyways
Plenty long for the two gaskets and factory windage tray plus the 402 oil pan
Mega Parts USA Oil Pan Bolt Set Big Block
Also Superformance Oil Pan Gaskets
http://www.megapartsusa.com/products.asp?cat=506
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: stock 383 oil pan 402 with windage tray [Re: bee1971] #2170883
10/09/16 01:37 PM
10/09/16 01:37 PM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
thanks
