is this cam right for me? #2169805
10/07/16 07:37 PM
10/07/16 07:37 PM
G code Jockey Offline OP
to start off this is my first post. i have just started the long road to build a nice 440 powered gen 3 single cab Dakota. i recently acquired a base machined block and forged crank along with a bunch of other speed parts. included was a comp cams 21-672-4 cam. the block has a .060 overbore and a forged crank. i also got a new set of edelbrock performer rpm 84cc heads to go with it. my intentions from the start are to build a hot street truck that will be driven to the drag strip every so often. it will have a 727 with an 8 3/4 rear end. so back to my question, is this cam to aggressive for a street vehicle. i know virtually nothing about cam specs and am trying to learn. if you guys need more info i will be happy to provide it. thanks
Re: is this cam right for me? [Re: G code Jockey] #2169807
10/07/16 07:43 PM
10/07/16 07:43 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
looks like this is your cam.
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=719&sb=2
gonna need alot of compression, alot of gear and and a loose stall converter.
Re: is this cam right for me? [Re: G code Jockey] #2169827
10/07/16 08:14 PM
10/07/16 08:14 PM
So. Burlington, Vt.
fast68plymouth Online content
fast68plymouth  Online Content
So. Burlington, Vt.
Comps version of the MP 509 cam.
If your build will include something like headers, 3.91 gears, and at least a 10"(3500 stall) converter...... It will be fine.
I'd recommend a Performer RPM intake and a carb with 4-corner idle.
Re: is this cam right for me? [Re: fast68plymouth] #2169833
10/07/16 08:25 PM
10/07/16 08:25 PM
absolutely headers and that was the gear i was thinking of as opposed to a 4.10 or deeper. would flat tops provide enough compression or is more needed. please forgive the greeny questions.
Re: is this cam right for me? [Re: G code Jockey] #2170053
10/08/16 01:21 AM
10/08/16 01:21 AM
So. Burlington, Vt.
So. Burlington, Vt.
As long as it's an honest 9.5:1 or higher you should be fine.
