How to get burnt oil off coated header???? #2168981
10/06/16 02:51 PM
10/06/16 02:51 PM
Alberta, Canada
451Guy Offline OP
451Guy  Offline OP
Alberta, Canada
Last time I was at the track for some reason my vacuum pump over flow tank sprayed oil all over my freshly coated fenderwell header. Any Idea on how to get it off. I tried brake clean with no success.
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank
Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car
Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T
Best ET 11.39 @ 118.11
Re: How to get burnt oil off coated header???? [Re: 451Guy] #2168991
10/06/16 03:07 PM
10/06/16 03:07 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Mother's Mag Wheel Polish worked for me on small areas and may need several applications. I've heard that "Never Dull" works as well.
http://www.nevrdull.com/
Re: How to get burnt oil off coated header???? [Re: 451Guy] #2168994
10/06/16 03:10 PM
10/06/16 03:10 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Ill second the mothers suggestion. Works great
Re: How to get burnt oil off coated header???? [Re: 451Guy] #2168998
10/06/16 03:15 PM
10/06/16 03:15 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
scotch brite pad and some house hold citrus degreaser.
Re: How to get burnt oil off coated header???? [Re: 451Guy] #2169006
10/06/16 03:22 PM
10/06/16 03:22 PM
Alberta, Canada
451Guy Offline OP
451Guy  Offline OP
Alberta, Canada
Thanks guys! I hope I can get it off! I was freakin out at the track!!!!! Serves me right for trying to make stuff look respectable!!!!!
Thanx 451 Guy
Re: How to get burnt oil off coated header???? [Re: 451Guy] #2169007
10/06/16 03:22 PM
10/06/16 03:22 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Had the same thing happen a couple of years ago. Bob George suggested oven cleaner to me and it worked.
Old Geezer Racing
Re: How to get burnt oil off coated header???? [Re: 451Guy] #2169026
10/06/16 03:53 PM
10/06/16 03:53 PM
central il.
second 70 Offline
second 70  Offline
central il.
I've had great luck just with a wet soapy sos pad.
Re: How to get burnt oil off coated header???? [Re: 451Guy] #2169028
10/06/16 03:56 PM
10/06/16 03:56 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
PM Mike Hynes (THESHAKERPROJECT) and ask him what he used to clean up my coated TTIs for me. They were pretty bleepin' disgusting, and now they're waaaaay better looking. up
Re: How to get burnt oil off coated header???? [Re: 451Guy] #2169111
10/06/16 06:18 PM
10/06/16 06:18 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Oven cleaner. Works like a charm and no elbow grease required.
Re: How to get burnt oil off coated header???? [Re: Cudajon] #2169125
10/06/16 06:33 PM
10/06/16 06:33 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
X2, doesn't harm the coating like adrasives.
Re: How to get burnt oil off coated header???? [Re: 451Guy] #2169364
10/06/16 11:58 PM
10/06/16 11:58 PM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
I used Wizard's metal renew on mine and the oil wiped right off (baked on from the Dyno and a couple track days). No discoloration at all. Make sure they're cool.
http://wizardsproducts.com/metal-renew-8-oz/
Re: How to get burnt oil off coated header???? [Re: 451Guy] #2169377
10/07/16 12:30 AM
10/07/16 12:30 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Careful with the Easy Off, don't leave it on there too long...
Re: How to get burnt oil off coated header???? [Re: 451Guy] #2169684
10/07/16 03:42 PM
10/07/16 03:42 PM
Alberta, Canada
451Guy Offline OP
451Guy  Offline OP
Alberta, Canada
Thanks Guys! Looks like I will be doing some cleaning this weekend.
Thanx 451 Guy
Re: How to get burnt oil off coated header???? [Re: 451Guy] #2169706
10/07/16 04:14 PM
10/07/16 04:14 PM
Cab_Burge Online work
Cab_Burge  Online Work
Easy Off may raise heck with aluminum heads work shruggy
Re: How to get burnt oil off coated header???? [Re: Cab_Burge] #2169758
10/07/16 05:50 PM
10/07/16 05:50 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Fast Orange hand cleaner works very well and no nasty smell..TTI even suggests using it on their headers.
Todd
