Re: 2013 Hemi Swap
[Re: Eric Rizner]
#2161684
09/25/16 11:51 PM
09/25/16 11:51 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Have you verified tooth count? I wouldnt guarantee that is problem. They are either 32 or 58 teeth. But according to Manley there are 2 types of 58 tooth, 2012 and earlier and 2013 and up. The early reluctor wheel has .170 gap between teeth and the later one has .130 gap between teeth. Also ALL VVT engines have 58 tooth wheels.
Mopar to the bone!!!
Re: 2013 Hemi Swap
[Re: 72Swinger]
#2168907
10/06/16 12:10 PM
10/06/16 12:10 PM
Posts: 3,842 Ohio
john55
Ohio
I agree, I have an '09 crank out of a Ram, it is .187 between teeth, and a '14 crank out of a Ram, .222 between teeth of the reluctor, will the '09 fit the '14 crank? hopefully I'll pull the '09 crank out of the block and check to see if the '09 reluctor will fit the '14 crank...hopefully this weekend....
The Plymouth Win You Over Beat Goes On
