Shackle angle #2166229
10/02/16 12:42 AM
10/02/16 12:42 AM
Hamilton, Ontario Canada
Magnum Offline OP
Magnum  Offline OP
69 Super Bee. 3" MP inboard kit. Front segment is good. Original spring was 22", SS is 20. Original hanger hole to new hole is 2" further back.
My question is where to drill rear shackle hole. I've read about 56" and 57" leaf springs. Dodge and Plymouth differences. I'm now running P3690454, P3690455 which is hard to measure curled up with no weight on them.
I plan on a pretty low ride height, even if I have to dearch the springs.
How far away from the front hole should my rear shackle tube be for a good shackle angle?
Re: Shackle angle [Re: Magnum] #2166256
10/02/16 01:51 AM
10/02/16 01:51 AM
I like the bottom of the "vertical" hangars to be a bit rearward (from 6 0'clock vertical) loaded so the spring does not raise the car which it would as the shackle arcs & goes over center if the shackle was pointing forward but rather the spring "compresses" as it works WO raising the car. first I would locate the springs so the axle/wheels are where they look best in the wheelwells
Re: Shackle angle [Re: Magnum] #2166366
10/02/16 11:56 AM
10/02/16 11:56 AM
Magnum Offline OP
Magnum  Offline OP
Ya Rapid, rearward angle for sure. So I centered my wheel in the wheelwell. Checked center of wheel to front leaf spring mounting hole. We have a good solid match at 20".
So basically how far back should the rear hole for the shackle mount be for the proper angle be? Im guessing a tiny bit shorter than a flattened out SS spring.
Re: Shackle angle [Re: Magnum] #2166369
10/02/16 12:03 PM
10/02/16 12:03 PM
I'm thinking that you might have to go ahead with an edumacated guess for a start & drill some holes for a mockup to get it assembled/loaded then redrill more from there as needed unfortunately
Re: Shackle angle [Re: Magnum] #2166485
10/02/16 03:13 PM
10/02/16 03:13 PM
I would move it three inches forward from the orignal hole to make the rear shackle angle better up twocents
Re: Shackle angle [Re: Cab_Burge] #2166536
10/02/16 04:43 PM
10/02/16 04:43 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I think you need to rethink the 3" dimension.
His front hanger is longer to account for the shorter front segment.
Don't be the exception.
Re: Shackle angle [Re: Magnum] #2166573
10/02/16 05:55 PM
10/02/16 05:55 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
this may be a good place to start. I used them on my dirt track cars.... way to complex and I am to lazy to type it all !! it will get you on the page .... https://landrumspring.com/technical/oval-track-leaf-spring-mounting-point/
Re: Shackle angle [Re: Supercuda] #2166633
10/02/16 08:04 PM
10/02/16 08:04 PM
You may have a point if the O.P. is going to use the longer rear front hangar to move the front hole back two inches and not slide the rear end forward to improve traction by shortening the wheelbase. I normally trim the front edge of the wheel wells two to three inches to move the rear end forward at least one inch,sometimes two inches or slightly more devil whistling
I haved had several different Mopar leaf spring kits installed into the rear sub frames of, A, B and E bodys. None of those cars had enough rear shackle angle stock to make me want to keep the rear shackle hole in the same relation to stock when switching to the Mopar brand SS leaf springs with the two inch shorter front segments SS rear springs, hence my recommendation to move the rear hole forward three inches to gain one more inch forward on the upper mount to help increase the rear shackle angle more increasing the rear shackle so the rear of the car will work better under WOT work scope
OP, make a mark on the rear sub frames with the same size hole as the current hole at one, two and three inches forward and look at those as a references to see what the rear shackle angle could be and pick the one you like the most scope Make your decisions from there up
Re: Shackle angle [Re: Cab_Burge] #2167528
10/04/16 05:22 AM
10/04/16 05:22 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
You can see the left rear shackle a little in this pic and get a good idea of the angle when everything is in stock location. As everything is in stock location on my 63. And the springs are not moved in any. Ron
Re: Shackle angle [Re: Magnum] #2168119
10/05/16 12:37 AM
10/05/16 12:37 AM
Harrisburg, Pa.
screamindriver Online content
screamindriver  Online Content
Harrisburg, Pa.
There's too many variables to tell where the optimum angle comes into play without the vehicle's final assembly including the dearching of the springs if you go that route...Drilling holes now will be a guess at best and you'll probably end up making more when it's all said and done...
I'd either install the shackles in the factory frame holes until the final assembly is done and you know what you've got to do...Or{if they don't fit} don't install the shackles, use a wood spacer between the frame and the rear spring eye and let the spring slide on the spacer until you're done assembling the car and have added all the weight..
Here's a diagram from the MP chasis manual...
Re: Shackle angle [Re: Magnum] #2168718
10/05/16 11:30 PM
10/05/16 11:30 PM
Magnum Offline OP
Magnum  Offline OP
Since the Ss Springs are based on an A body size. If anyone has an A body. The front mounting hole to rear shackle hole should be all I would need.
Can we assume a Ss spring in an A body will have the perfect shackle angle?
Re: Shackle angle [Re: Magnum] #2168731
10/05/16 11:48 PM
10/05/16 11:48 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
57.26" center to center (front pivot hole to rear frame hole if I am reading my 71 FSM correctly.
Or measure original distance and subtract 2".
Re: Shackle angle [Re: Magnum] #2168767
10/06/16 01:10 AM
10/06/16 01:10 AM
No, absolutely not! Install your springs first and then look at the rear shackle angles scope Mopar made a bunch of different SS drag race springs as well as road handling SS type springs, not all of them will work well with stock front mounts and stock rear shackle hole locations shruggy
Re: Shackle angle [Re: Magnum] #2169258
10/06/16 09:47 PM
10/06/16 09:47 PM
Washington
madscientist Offline
Washington
What about installing a slider back there?
