Shackle angle
#2166229
10/02/16 12:42 AM
10/02/16 12:42 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
69 Super Bee. 3" MP inboard kit. Front segment is good. Original spring was 22", SS is 20. Original hanger hole to new hole is 2" further back.
My question is where to drill rear shackle hole. I've read about 56" and 57" leaf springs. Dodge and Plymouth differences. I'm now running P3690454, P3690455 which is hard to measure curled up with no weight on them.
I plan on a pretty low ride height, even if I have to dearch the springs.
How far away from the front hole should my rear shackle tube be for a good shackle angle?
Re: Shackle angle
[Re: Magnum]
#2166256
10/02/16 01:51 AM
10/02/16 01:51 AM
RapidRobert
I like the bottom of the "vertical" hangars to be a bit rearward (from 6 0'clock vertical) loaded so the spring does not raise the car which it would as the shackle arcs & goes over center if the shackle was pointing forward but rather the spring "compresses" as it works WO raising the car. first I would locate the springs so the axle/wheels are where they look best in the wheelwells
Re: Shackle angle
[Re: Magnum]
#2166366
10/02/16 11:56 AM
10/02/16 11:56 AM
Magnum
Ya Rapid, rearward angle for sure. So I centered my wheel in the wheelwell. Checked center of wheel to front leaf spring mounting hole. We have a good solid match at 20".
So basically how far back should the rear hole for the shackle mount be for the proper angle be? Im guessing a tiny bit shorter than a flattened out SS spring.
Re: Shackle angle
[Re: Magnum]
#2166369
10/02/16 12:03 PM
10/02/16 12:03 PM
RapidRobert
I'm thinking that you might have to go ahead with an edumacated guess for a start & drill some holes for a mockup to get it assembled/loaded then redrill more from there as needed unfortunately
Re: Shackle angle
[Re: Cab_Burge]
#2166536
10/02/16 04:43 PM
10/02/16 04:43 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I think you need to rethink the 3" dimension.
His front hanger is longer to account for the shorter front segment.
Re: Shackle angle
[Re: Supercuda]
#2166633
10/02/16 08:04 PM
10/02/16 08:04 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
His front hanger is longer to account for the shorter front segment. You may have a point if the O.P. is going to use the longer rear front hangar to move the front hole back two inches and not slide the rear end forward to improve traction by shortening the wheelbase. I normally trim the front edge of the wheel wells two to three inches to move the rear end forward at least one inch,sometimes two inches or slightly more I haved had several different Mopar leaf spring kits installed into the rear sub frames of, A, B and E bodys. None of those cars had enough rear shackle angle stock to make me want to keep the rear shackle hole in the same relation to stock when switching to the Mopar brand SS leaf springs with the two inch shorter front segments SS rear springs, hence my recommendation to move the rear hole forward three inches to gain one more inch forward on the upper mount to help increase the rear shackle angle more increasing the rear shackle so the rear of the car will work better under WOT OP, make a mark on the rear sub frames with the same size hole as the current hole at one, two and three inches forward and look at those as a references to see what the rear shackle angle could be and pick the one you like the most Make your decisions from there
Re: Shackle angle
[Re: Magnum]
#2168718
10/05/16 11:30 PM
10/05/16 11:30 PM
Magnum
Since the Ss Springs are based on an A body size. If anyone has an A body. The front mounting hole to rear shackle hole should be all I would need.
Can we assume a Ss spring in an A body will have the perfect shackle angle?
Re: Shackle angle
[Re: Magnum]
#2168731
10/05/16 11:48 PM
10/05/16 11:48 PM
Supercuda
About to go away
About to go away
up yours
57.26" center to center (front pivot hole to rear frame hole if I am reading my 71 FSM correctly.
Or measure original distance and subtract 2".
Re: Shackle angle
[Re: Magnum]
#2168767
10/06/16 01:10 AM
10/06/16 01:10 AM
Cab_Burge
No, absolutely not! Install your springs first and then look at the rear shackle angles Mopar made a bunch of different SS drag race springs as well as road handling SS type springs, not all of them will work well with stock front mounts and stock rear shackle hole locations
Re: Shackle angle
[Re: Magnum]
#2169258
10/06/16 09:47 PM
10/06/16 09:47 PM
Posts: 4,457 Washington
madscientist
Washington
What about installing a slider back there?
