Paint line half way up the firewall?
#2166936
10/03/16 11:25 AM
10/03/16 11:25 AM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
How and why is there a sharp, masked paint line on the interior of the firewall? No paint on the top half and underside of the cowl. Is this for ease of grounding or something? It definitely took effort, which means it was done for a reason. This is in my '68 Charger... ![](http://img.photobucket.com/albums/v227/67Charger/68%20Charger%20slant%206/20161001_233018_zpswikbxrrk.jpg)
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: Paint line half way up the firewall?
[Re: Stanton]
#2167203
10/03/16 06:29 PM
10/03/16 06:29 PM
Posts: 892 MA
steve70
MA
That doesn't explain why that line seperates bare metal from color coat. Regardless of the dip there should at least be overspray above the dip line. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) Here a picture of an original T/A
1970 Challenger T/A 4 speed
[Re: 67Charger]
#2167499
10/04/16 02:31 AM
10/04/16 02:31 AM
67Charger
Erda, UT
Unless it was blue primer...
That it a hard line there. If you look above the passenger cowl vent opening, there is some blue overspray with some glue and insulation stuck on it.
[Re: Stanton]
#2167694
10/04/16 01:31 PM
10/04/16 01:31 PM
Posts: 2,295 Land of 10,000 Lakes
44D6PAKCUDA
The factory was using blue primer now ?!?!?!? I think maybe the flash or lighting makes it look more blue than it really is.Looks very close to Resto Ricks primer dip formula.
[Re: 67Charger]
#2167995
10/04/16 08:56 PM
10/04/16 08:56 PM
Posts: 5,943 ohio
ruderunner
ohio
My 69 RR had a pretty dark gray dip. I'll have to look closer at my coronet.
Angry white pureblood male
[Re: 71GTX471]
#2168188
10/05/16 02:49 AM
10/05/16 02:49 AM
67Charger
Erda, UT
67charger is the body blue also,is the firewall paint primer like or body paint,sure looks like a dip line to me higher on the R/side then left. I'll go snap another picture. It is the exact shade of blue that the car is and was, just not glossy.
[Re: 67Charger]
#2168810
10/06/16 03:12 AM
10/06/16 03:12 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Of course it's a dip line. It's probably in the trunk too, as well as on the wheel tubs, the diagonal braces behind the rear seat, and on the inner quarter panels.
