Paint line half way up the firewall? #2166936
10/03/16 11:25 AM
10/03/16 11:25 AM
Erda, UT
67Charger Offline OP
Erda, UT
How and why is there a sharp, masked paint line on the interior of the firewall? No paint on the top half and underside of the cowl. Is this for ease of grounding or something? It definitely took effort, which means it was done for a reason.
This is in my '68 Charger...
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: Paint line half way up the firewall? [Re: 67Charger] #2166940
10/03/16 11:41 AM
10/03/16 11:41 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The completed main bodies after major assy, went into a series of "baths", the primer dip being the last before going off to paint, that's the reason for all the floor body plugs, to drain the chassis after dipping
Re: Paint line half way up the firewall? [Re: 67Charger] #2166941
10/03/16 11:41 AM
10/03/16 11:41 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Looks like a "dip" line. The lower part of the body went through a dip tank to rust proof the body at the factory.
Re: Paint line half way up the firewall? [Re: 67Charger] #2166948
10/03/16 11:57 AM
10/03/16 11:57 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Illustration showing the dip process at http://www.hamtramck-historical.com/imag...neering0010.jpg
Re: Paint line half way up the firewall? [Re: 67Charger] #2167166
10/03/16 05:36 PM
10/03/16 05:36 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
That doesn't explain why that line seperates bare metal from color coat. Regardless of the dip there should at least be overspray above the dip line.
Re: Paint line half way up the firewall? [Re: Stanton] #2167203
10/03/16 06:29 PM
10/03/16 06:29 PM
MA
steve70 Offline
steve70  Offline
MA
iagree
Here a picture of an original T/A
1970 Challenger T/A 4 speed
Re: Paint line half way up the firewall? [Re: 67Charger] #2167291
10/03/16 08:55 PM
10/03/16 08:55 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Why would there have to be a color coat above the dip line ???Looks like the color coat barely made it to the dip line let alone painting much past it on the other examples...I'm thinking the color coat is a close match to the dip primer and the overspray was enough to tint the primer making it appear it's a taped color coat line...
Re: Paint line half way up the firewall? [Re: 67Charger] #2167470
10/04/16 01:14 AM
10/04/16 01:14 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
In the op's photo it definitely looks blue up to that line. Was the dip blue? Not on my car! It just looks like bare metal.
Re: Paint line half way up the firewall? [Re: 67Charger] #2167499
10/04/16 02:31 AM
10/04/16 02:31 AM
Erda, UT
Erda, UT
Unless it was blue primer...
That it a hard line there. If you look above the passenger cowl vent opening, there is some blue overspray with some glue and insulation stuck on it.
Re: Paint line half way up the firewall? [Re: 67Charger] #2167595
10/04/16 10:43 AM
10/04/16 10:43 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The factory was using blue primer now ?!?!?!?
Re: Paint line half way up the firewall? [Re: 67Charger] #2167627
10/04/16 11:45 AM
10/04/16 11:45 AM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
Prior to dipping I assume.
Re: Paint line half way up the firewall? [Re: Stanton] #2167694
10/04/16 01:31 PM
10/04/16 01:31 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline
44D6PAKCUDA  Offline
I think maybe the flash or lighting makes it look more blue than it really is.Looks very close to Resto Ricks primer dip formula.
Re: Paint line half way up the firewall? [Re: 67Charger] #2167979
10/04/16 08:18 PM
10/04/16 08:18 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
67charger is the body blue also,is the firewall paint primer like or body paint,sure looks like a dip line to me higher on the R/side then left.
Re: Paint line half way up the firewall? [Re: 67Charger] #2167995
10/04/16 08:56 PM
10/04/16 08:56 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
My 69 RR had a pretty dark gray dip.
I'll have to look closer at my coronet.
Angry white pureblood male
Re: Paint line half way up the firewall? [Re: 71GTX471] #2168188
10/05/16 02:49 AM
10/05/16 02:49 AM
Erda, UT
Erda, UT
I'll go snap another picture. It is the exact shade of blue that the car is and was, just not glossy.
Re: Paint line half way up the firewall? [Re: 67Charger] #2168347
10/05/16 01:48 PM
10/05/16 01:48 PM
Erda, UT
Erda, UT
Got to be a dip line. It is quite close to blue, but it must be just enough blue matallic overspray to make it look like dull blue paint. Seeing the floor and door in the same picture puts it back in perspective.
Re: Paint line half way up the firewall? [Re: 67Charger] #2168810
10/06/16 03:12 AM
10/06/16 03:12 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Of course it's a dip line. It's probably in the trunk too, as well as on the wheel tubs, the diagonal braces behind the rear seat, and on the inner quarter panels.
