Re: Restoring original positive battery cable
[Re: C_B5]
#2166236
10/02/16 01:10 AM
10/02/16 01:10 AM
Posts: 306 Georgia
69bfan
Georgia
We can take your existing cable and cut the damaged head away leaving the exposed wires. Then a correct style head is poured back around the existing cable much as the reproduction or any battery cable for that matter is made. We have done this on several cables both positive and negative so that the car could retain the original cables. There is a difference in what I call the Packard brick red color of an original cable vs the more pinkish red found on the cables on the market today. We have seen on some cables that there is some oxidation of the metal and it has to be trimmed back slightly, but there is most times enough excess not to be an issue. The service runs approximately $35 to replace the head. If it needs to be retaped or the starter lug replaced, it will be slightly more. If you have any questions give me a call or I will be at the Hershey meet and I will be glad to answer any questions. Richard O'Shields Restoration Parts and Materials 404-643-5760
www.restorationpartsandmaterials.comCorrect Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs. www.dalescudashop.comCorrect style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
[Re: whomper1]
#2166985
10/03/16 12:47 PM
10/03/16 12:47 PM
Posts: 306 Georgia
69bfan
Georgia
I am currently out of town getting ready for the Hershey meet, but will attempt to get a before and after picture to post. Thanks, Richard
