Engine and Transmission Cradle Plans #2164782
09/29/16 11:23 PM
09/29/16 11:23 PM
70RT Offline OP
70RT  Offline OP
Guys - was hoping someone here would be willing to share their plans/specs/pictures of an k-frame/engine/tranny cradle used when taking the drivetrain with suspension attached out from the bottom. Appreciate any and all help provided. I have a local fabricator lined up just need some starting points. TIA!
Re: Engine and Transmission Cradle Plans [Re: 70RT] #2164834
09/30/16 12:36 AM
09/30/16 12:36 AM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
Here is one I made that supports the engine by the oil pan. Fits BB and SB and rides on top of a motorcycle jack, making it easy to maneuver.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: Engine and Transmission Cradle Plans [Re: 70RT] #2164999
09/30/16 10:40 AM
09/30/16 10:40 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
PM an e-mail address for set of plans, I'm not on my computer and cant figure out how to upload the doc from an e-mail but I can forward it and then someone could attach it.
Careful, your character's showing!
Re: Engine and Transmission Cradle Plans [Re: mopar346] #2166445
10/02/16 02:20 PM
10/02/16 02:20 PM
70RT Offline OP
70RT  Offline OP
Thanks for the replies guys!
Re: Engine and Transmission Cradle Plans [Re: 70RT] #2166707
10/02/16 10:04 PM
10/02/16 10:04 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
This is one I made several years ago for my 68 RR project. I made it a little taller so I could have room to work it under my lift as I was bolting it in. Couple of small issues I ran into was with the Milodon oil pan and K-frame - I needed to put a notch in the one upper rail to clear the pan. I also put some nylon sheet scraps on the top to protect the paint (wood would work just as well). I used a spare scissor jack I got out of some car at the junkyard to allow me to fine adjust the angle during installation (weld it to the cradle so it does not move). I also put the spindles and brakes together on the K-frame initially but since my lift was a 4-post style I had to remove them to clear the lift tracks. It was probably a little overkill for a one time shot but I gave it to a mopar restoration shop so it still sees good use.
Re: Engine and Transmission Cradle Plans [Re: 68jim] #2166781
10/03/16 12:05 AM
10/03/16 12:05 AM
70RT Offline OP
70RT  Offline OP
Thanks Jim! That's exactly what I needed.
Re: Engine and Transmission Cradle Plans [Re: 70RT] #2166885
10/03/16 05:12 AM
10/03/16 05:12 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
70RT,
Are you using a lift? 2 post or 4 post? Or are you lifting the front end high with the rear end as the pivot point?
My style cradle will work fine with a lift but is too tall for the pivot method.
Re: Engine and Transmission Cradle Plans [Re: 68jim] #2167383
10/03/16 10:57 PM
10/03/16 10:57 PM
70RT Offline OP
70RT  Offline OP
Two post lift. The only point I'm not clear on is the front two front contact points. Engine or K-frame? Thanks!
Re: Engine and Transmission Cradle Plans [Re: 70RT] #2167540
10/04/16 06:59 AM
10/04/16 06:59 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Two post lift will make it much easier. I also had to put 4 notches in the drip pan lips on the lift tracks to clear the K-frame "ears". The process, once I started pushing the motor under the car, took all of 20 minutes until I was raising the car to clear the cradle. I added a few more pictures - the K-frame is what makes contact to the cradle front contact points. I do not have an exact measurement for height but you get an idea of how much room we had to bolt in the trans cross member. If you make it higher for more room the tradeoff will be in the overall stability, or just make it wider as well.
Good luck - would like to see pics of what you end up with.
