From the factory, the ground cable does not have a small pigtail wire. The factory positive cable large end attached to the stud on the starter. The smaller gauge wires feeds to the relay on the firewall. There is an additional wire from the relay down to small stud to starter (brown wire). Pull up a wire diagram form the year car and you can see how it should be wired.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
