Question about the small battery cable wires #2163068
09/27/16 07:54 PM
09/27/16 07:54 PM
NorCal
fatsat Offline OP
fatsat  Offline OP
NorCal
Where do the small wires connect to?
Re: Question about the small battery cable wires [Re: fatsat] #2163091
09/27/16 08:31 PM
09/27/16 08:31 PM
Portland, OR
shawge Offline
shawge  Offline
Portland, OR
Battery post on starter relay
Frame ground point
Re: Question about the small battery cable wires [Re: fatsat] #2163092
09/27/16 08:32 PM
09/27/16 08:32 PM
Universal (non Mopar) cables. you could run the neg one to the radiator support or any nearby ground. Likely no use for the red pigtail
Re: Question about the small battery cable wires [Re: shawge] #2163369
09/28/16 01:38 AM
09/28/16 01:38 AM
NorCal
fatsat Offline OP
fatsat  Offline OP
NorCal
Ok
Re: Question about the small battery cable wires [Re: fatsat] #2164084
09/29/16 12:40 AM
09/29/16 12:40 AM
I'd go ahead & run the large red cable to the starter relay large batt stud then a large cable from that stud down to the starter (std Mopar routing) and the black large cable to the block & the black pigtail to any nearby ground & in addition a good braided cable or regular cable from block to firewall
Re: Question about the small battery cable wires [Re: fatsat] #2166743
10/02/16 11:19 PM
10/02/16 11:19 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
From the factory, the ground cable does not have a small pigtail wire. The factory positive cable large end attached to the stud on the starter. The smaller gauge wires feeds to the relay on the firewall. There is an additional wire from the relay down to small stud to starter (brown wire). Pull up a wire diagram form the year car and you can see how it should be wired.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
