Help in ID'ing Skid Plate K-member w/pics #2164119
09/29/16 01:59 AM
09/29/16 01:59 AM
So Cal
autoxcuda Offline OP
So Cal
I've got a skid plate K-member with the numbers stamped in it:
130032
Is this a E-body and 71-72 Body K-member or a 70 B-body K-member?
Re: Help in ID'ing Skid Plate K-member w/pics [Re: autoxcuda] #2164152
09/29/16 04:34 AM
09/29/16 04:34 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Are you sure that is not the vendor code?
The part number would be on a coin if the K member had a coin
Re: Help in ID'ing Skid Plate K-member w/pics [Re: autoxcuda] #2164237
09/29/16 11:09 AM
09/29/16 11:09 AM
Indianapolis, IN
B5Cuda440-6 Offline
B5Cuda440-6  Offline
Indianapolis, IN
Morty is correct, the last 2 digits of the part number are located on a small coin welded on the front of the skidplate. The only numbers stamped into the K member itself would be the vendor and date codes.
Re: Help in ID'ing Skid Plate K-member w/pics [Re: autoxcuda] #2164288
09/29/16 12:29 PM
09/29/16 12:29 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Vendor codes are 5 digits.
Re: Help in ID'ing Skid Plate K-member w/pics [Re: autoxcuda] #2164356
09/29/16 01:43 PM
09/29/16 01:43 PM
So Cal
So Cal
No coin on this k member.
Anyway else ID it as 70 b-body OR E-body/71-72B-body ???
Re: Help in ID'ing Skid Plate K-member w/pics [Re: autoxcuda] #2164379
09/29/16 02:20 PM
09/29/16 02:20 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
are there any other numbers stamped in the front center of it? They would face the front of the car and get bugs splattered on them when driving.
Re: Help in ID'ing Skid Plate K-member w/pics [Re: autoxcuda] #2164407
09/29/16 03:01 PM
09/29/16 03:01 PM
Central Texas
b_body_fan Offline
b_body_fan  Offline
Central Texas
I have an original 71 Charger R/T with a skid plate and no coin welded to the K-member, I would say it is a 71-72 b-body, e-body skid plate.
Re: Help in ID'ing Skid Plate K-member w/pics [Re: NANKET] #2164495
09/29/16 04:57 PM
09/29/16 04:57 PM
So Cal
So Cal
Those are the only numbers I can see. It's been blasted and powdercoated. frown
Any angles or features to determine the differences.
Re: Help in ID'ing Skid Plate K-member w/pics [Re: autoxcuda] #2164625
09/29/16 08:02 PM
09/29/16 08:02 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
I think E body had a different steering box mounting angle you would need that spec. & measure then you would be closer to knowing.
Re: Help in ID'ing Skid Plate K-member w/pics [Re: 71GTX471] #2165401
09/30/16 09:07 PM
09/30/16 09:07 PM
cataclysm80 Offline
cataclysm80  Offline
70-74 E body and 71-72 B body are the same.
Earlier B body has a different steering box angle. 3 degrees different I think.
1970 sway bar mounts different than the earlier bars.
73 and later B body is also different due to isolators.
Tav
