rack n pinion , what happens when it goes bad? *DELETED* #216097
02/06/09 06:40 PM
02/06/09 06:40 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
Post deleted by dirt
Re: rack n pinion , what happens when it goes bad? [Re: dirt] #216098
02/06/09 06:57 PM
02/06/09 06:57 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
That's bad.
Common issues are cold sticking, leaking, and the occasional no power like you had.
Replace ASAP.
Re: rack n pinion , what happens when it goes bad? [Re: dirt] #216099
02/06/09 06:57 PM
02/06/09 06:57 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Sounds like that's what happens when they go bad.
I wouldn't chance this on the road till you get it fixed. Could kill
Re: rack n pinion , what happens when it goes bad? [Re: dirt] #216100
02/06/09 07:46 PM
02/06/09 07:46 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I have a 95 dakota and i think the rack is going bad.it has 155,000 miles on it and when i turned out of my driveway today it got stuck on a turn and would not turn anymore it about ran me into a bank. if you give it a jerk it will go past the catching spot. i am not sure the thing always catches in the same spot but it got stuck a few times within 1 mile so i came back home
If it does it worse(lack of power assist)cold, we call it morning sickness. It will need a new rack. Don't forget to flush the system w/clean fluid so you don't hurt the new rack!
Re: rack n pinion , what happens when it goes bad? [Re: Dcuda69] #216101
02/06/09 08:52 PM
02/06/09 08:52 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
I have a brand X car, a Buick, that has had this "morning sickness" for at least 13 years and over 100 thousand miles. Needs a little fluid every month or so, and the first mile in the morning the pump is a little noisy. I am surprised I have been able to go so long obviously needing a new rack and probably a new pump. So don't panic and give up unless you are just more conscientious than me. I save my money for Cudas and Roadrunners. The daily drivers are beaters for work.
Re: rack n pinion , what happens when it goes bad? [Re: dirt] #216102
02/07/09 12:28 AM
02/07/09 12:28 AM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
You have GOT to be kidding!!!!
Re: rack n pinion , what happens when it goes bad? [Re: RodStRace] #216103
02/07/09 12:55 AM
02/07/09 12:55 AM
That's bad.
Replace ASAP.
Start shopping around for another rack.
It's a pretty easy job.
I replaced one in a brand x van for under $200
This included a gently used rack, 2 new front tires and alignment.
Re: rack n pinion , what happens when it goes bad? [Re: earlybee] #216104
02/07/09 01:07 AM
02/07/09 01:07 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
i dont mean that the rack lost the power . it was more like something jamed it and it would not move no matter how hard i tried. i had to turn it back the opposit direction and try again.i was backing it up and it jammed i turned as hard as i could and it wouldnt move at all until i reversed it then tried it again.
i have driven it before when the belt broke on the pump and could still steer it, but this was different.
Re: rack n pinion , what happens when it goes bad? [Re: dirt] #216105
02/07/09 01:49 AM
02/07/09 01:49 AM
Well if you've ruled out the rack being bad, then I would look for badly worn and possibly binding suspension components.
I would still suspect the rack though.
It's a hydraulic system and when a valve sticks it really don't matter how hard you try it's not going to budge.
There is a small company near me called HAPCO, they make additives, one in particular is called "rack 'n' pinion formula."
It frees up sticking valves in some applications.
It don't work for everyone but I used it once in a chevy cavalier that was doing what you were describing and it actually worked.
Check your local auto parts to see if they carry such an additive that you can try but remember that it's a last resort fix and even if it works you still may need to replace it shortly after using it.
Re: rack n pinion , what happens when it goes bad? #216106
02/07/09 02:26 AM
02/07/09 02:26 AM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
Your rack is bad. The teath and worm gear are no longer meshing correctly and causing it to bind. It's only going to get worse. My mother in law put her brand X in a ditch at 45 because of this EXACT same thing. She was on her way to get it replaced at the time.
Re: rack n pinion , what happens when it goes bad? [Re: None2Slow] #216107
02/07/09 03:36 AM
02/07/09 03:36 AM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
Before you go out and buy a rack, check the intermediate shaft u joints to make sure they are not siezed. You might have to take it off the rack end to do this. (one 13mm bolt) HTH.
