Which shackle kit to get #2160265
09/23/16 05:37 PM
09/23/16 05:37 PM
Hamilton, Ontario Canada
Magnum Offline OP
Magnum  Offline OP
I have a 69 Super Bee. Have the MP 3" inboard kit and 454, 455 Super stock springs.
I can not find my shackles so I need to order another set. There seems to be so many choices on the MP site.
Which ones do I need? I have a bushing that mounts to the rear hole in the frame. The OD of the bushing is 1"
Re: Which shackle kit to get [Re: Magnum] #2160623
09/24/16 01:56 AM
09/24/16 01:56 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
When I put SS springs on my 63 years ago I decided I wanted to raise the rear about 1/2" to 1" so I bought these Mr Gasket shackles which was this kit with the 1/2" bolts. I went with this kit because I wanted to raise my car a tad and this kit had extra holes to raise the rear a bit. And this kit was a good choice as they are nice thick metal and they are very strong. Once I decided which holes to use that raise the rear a little less then an inch I cut the extra off and rounded the corners a little to make them look like stock shackles. I also painted them black. One thing I hate and did not want was the extra shackle hanging down in the back as I hate seeing that on a car. They worked great and are stronger then the stock type were. Ron
https://www.summitracing.com/parts/mrg-1300
Re: Which shackle kit to get [Re: Magnum] #2160630
09/24/16 02:04 AM
09/24/16 02:04 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Here is a pic of the shackle after I trimmed it and painted them They have actually been on the car for over a year when I took this pic. Ron
Re: Which shackle kit to get [Re: Magnum] #2160633
09/24/16 02:12 AM
09/24/16 02:12 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
And this is how it sits with the Mr Gasket shackles. What I really liked about them is they gave me the option to raise or lower the car a little and they a strong solid shackle. And easy to trim the extra off as I did with my grinding wheel on my air drill tool (wizzer air tool that runs to 22,000 rpm). Ron
Re: Which shackle kit to get [Re: Magnum] #2160664
09/24/16 05:01 AM
09/24/16 05:01 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Re: Which shackle kit to get [Re: justinp61] #2160671
09/24/16 05:44 AM
09/24/16 05:44 AM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
Originally Posted By justinp61
Ditto for me. Really stout pieces.
I’m listening.
Re: Which shackle kit to get [Re: Magnum] #2161169
09/25/16 01:30 AM
09/25/16 01:30 AM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
Hotchkis makes a pretty nice looking kit.
I'm in need of a set myself, and am gonna order these.
https://m.summitracing.com/parts/hss-17367
Re: Which shackle kit to get [Re: Magnum] #2164383
09/29/16 02:27 PM
09/29/16 02:27 PM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
You'll need a set with a 9/16" I.D. bushings.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: Which shackle kit to get [Re: Magnum] #2164444
09/29/16 03:46 PM
09/29/16 03:46 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
http://www.manciniracing.com/manbebodset.html
sorry, i should have added why.
if you are going to run your exhaust in the stock location it will be a tight, tight fit with a nut and bolt fastener. the 'rods' on these are pressed in and will not interfere or bang against the pipe.
i have the same setup but on a 69 RR.
Re: Which shackle kit to get [Re: Magnum] #2165122
09/30/16 02:23 PM
09/30/16 02:23 PM
Magnum Offline OP
Magnum  Offline OP
What shackle kit would have come with the 3" relocation kit?
Re: Which shackle kit to get [Re: Magnum] #2166335
10/02/16 10:12 AM
10/02/16 10:12 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
the one i posted
Re: Which shackle kit to get [Re: Magnum] #2166350
10/02/16 10:49 AM
10/02/16 10:49 AM
Magnum Offline OP
Magnum  Offline OP
I have a very special fuel tank from an AMC. It resembles the B body in every way except its narrower so I can run tails.
I will order the B body racing shackle, thanks.
Re: Which shackle kit to get [Re: mikemee1331] #2167531
10/04/16 05:56 AM
10/04/16 05:56 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Mikemee1331 the shackle kit you posted looks to be a really nice shackle kit. The only reason I did not use them and I went with the Mr Gasket shackle kit was I wanted to raise the back of my car about 3/4 of and inch, Actually the Mr Gasket kit was the only one I found that has extra holes to raise or lower the car a little and that was a very strong shackle also. I wish they made the ones like you posted Mike in a few different lenths because they look just like the factory ones as far as I can tell. Ron
Re: Which shackle kit to get [Re: Magnum] #2167612
10/04/16 11:12 AM
10/04/16 11:12 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
The reason I bought the Prothane kit is that it has steel bushings that the bolts go through instead of just the rubber. The bushings free the shackle up to move easier. If I were only concerned about factory looks I would go a different route.
