Which shackle kit to get
#2160265
09/23/16 05:37 PM
09/23/16 05:37 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
I have a 69 Super Bee. Have the MP 3" inboard kit and 454, 455 Super stock springs.
I can not find my shackles so I need to order another set. There seems to be so many choices on the MP site.
Which ones do I need? I have a bushing that mounts to the rear hole in the frame. The OD of the bushing is 1"
Re: Which shackle kit to get
[Re: Magnum]
#2160623
09/24/16 01:56 AM
09/24/16 01:56 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
When I put SS springs on my 63 years ago I decided I wanted to raise the rear about 1/2" to 1" so I bought these Mr Gasket shackles which was this kit with the 1/2" bolts. I went with this kit because I wanted to raise my car a tad and this kit had extra holes to raise the rear a bit. And this kit was a good choice as they are nice thick metal and they are very strong. Once I decided which holes to use that raise the rear a little less then an inch I cut the extra off and rounded the corners a little to make them look like stock shackles. I also painted them black. One thing I hate and did not want was the extra shackle hanging down in the back as I hate seeing that on a car. They worked great and are stronger then the stock type were. Ron https://www.summitracing.com/parts/mrg-1300
[Re: Magnum]
#2164383
09/29/16 02:27 PM
09/29/16 02:27 PM
Posts: 860 lancaster,california
johnnycuda
You'll need a set with a 9/16" I.D. bushings.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: Magnum]
#2164444
09/29/16 03:46 PM
09/29/16 03:46 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
http://www.manciniracing.com/manbebodset.htmlsorry, i should have added why. if you are going to run your exhaust in the stock location it will be a tight, tight fit with a nut and bolt fastener. the 'rods' on these are pressed in and will not interfere or bang against the pipe. i have the same setup but on a 69 RR.
[Re: Magnum]
#2166335
10/02/16 10:12 AM
10/02/16 10:12 AM
mikemee1331
bethlehem pa
What shackle kit would have come with the 3" relocation kit? the one i posted
[Re: Magnum]
#2166350
10/02/16 10:49 AM
10/02/16 10:49 AM
Magnum
I have a very special fuel tank from an AMC. It resembles the B body in every way except its narrower so I can run tails.
I will order the B body racing shackle, thanks.
[Re: mikemee1331]
#2167531
10/04/16 05:56 AM
10/04/16 05:56 AM
383man
Balt. Md
Mikemee1331 the shackle kit you posted looks to be a really nice shackle kit. The only reason I did not use them and I went with the Mr Gasket shackle kit was I wanted to raise the back of my car about 3/4 of and inch, Actually the Mr Gasket kit was the only one I found that has extra holes to raise or lower the car a little and that was a very strong shackle also. I wish they made the ones like you posted Mike in a few different lenths because they look just like the factory ones as far as I can tell. Ron
