Brett's pass with new gears #2158328
09/20/16 09:45 PM
09/20/16 09:45 PM
Hilltown Pa
1967dartgt Offline OP
Hilltown Pa
https://youtu.be/T_adcqSkB1I
Tried more gear in the 411 NA small block.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Brett's pass with new gears [Re: 1967dartgt] #2158337
09/20/16 09:51 PM
09/20/16 09:51 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Sweet,time for bars.
Re: Brett's pass with new gears [Re: 1967dartgt] #2158378
09/20/16 10:47 PM
09/20/16 10:47 PM
Hilltown Pa
Hilltown Pa
Re: Brett's pass with new gears [Re: 1967dartgt] #2158379
09/20/16 10:47 PM
09/20/16 10:47 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Wow crazy bounce front end must be real real loose. Hopefully the car isn't hurt
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Brett's pass with new gears [Re: 1967dartgt] #2158387
09/20/16 10:54 PM
09/20/16 10:54 PM
Hilltown Pa
Hilltown Pa
By the forth pass we swapped the 4.30 gears back in.
https://youtu.be/s0xQoVksBxQ
Re: Brett's pass with new gears [Re: 1967dartgt] #2158390
09/20/16 10:56 PM
09/20/16 10:56 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Hopefully he didn't bend the car. Time for bars for sure or a different setup. Popping up way to fast, not the greatest way to set it up.
Re: Brett's pass with new gears [Re: 1967dartgt] #2158397
09/20/16 11:04 PM
09/20/16 11:04 PM
Hilltown Pa
Hilltown Pa
Front afcos were full tight on third pass and five clicks from full tight on second pass. Just needs more weight on front with the radials. Car is fine, didn't touch headers or oil pan. Oh he don't like bars so that's not a option at this time.
Re: Brett's pass with new gears [Re: 1967dartgt] #2158418
09/20/16 11:18 PM
09/20/16 11:18 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Glide.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Brett's pass with new gears [Re: B3422W5] #2158436
09/20/16 11:35 PM
09/20/16 11:35 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
Re: Brett's pass with new gears [Re: 1967dartgt] #2158437
09/20/16 11:36 PM
09/20/16 11:36 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Fourth pass looks great, new gears and the 400# of sand bags out of the trunk , right. :>} No way did just a gear change to 4.30,s made that much difference.
Re: Brett's pass with new gears [Re: 1967dartgt] #2158443
09/20/16 11:38 PM
09/20/16 11:38 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I think the video speed is off, making it look like its slamming down harder than it really is.
68 Barracuda Formula S 340
Re: Brett's pass with new gears [Re: Sport440] #2158447
09/20/16 11:42 PM
09/20/16 11:42 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
Only change was gears
Made the swap between rounds.
Re: Brett's pass with new gears [Re: Bad340fish] #2158449
09/20/16 11:43 PM
09/20/16 11:43 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
No it came down Hard.
Re: Brett's pass with new gears [Re: 1967dartgt] #2158471
09/20/16 11:57 PM
09/20/16 11:57 PM
Out West
408strokerdart Offline
Out West
Did you add weight to the front before taking gear out of it? Making some power.
Re: Brett's pass with new gears [Re: 408strokerdart] #2158507
09/21/16 12:50 AM
09/21/16 12:50 AM
Hilltown Pa
Hilltown Pa
No we didn't have any with us. Brett thinks it will be faster to eighth with steep gears in it.
Re: Brett's pass with new gears [Re: Sport440] #2158511
09/21/16 12:55 AM
09/21/16 12:55 AM
Hilltown Pa
Hilltown Pa
Went from 4.86s to 4.30s that's it. Shocks and weight of car the same.
Re: Brett's pass with new gears [Re: W5DART66] #2158527
09/21/16 01:20 AM
09/21/16 01:20 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Looks like it bounced back up.. been there done that..
when my struts blew out it would do that in all 3 gears
on my junker... HAD to get them rebuilt plus it bent the
ball joint stud on them
wave
Re: Brett's pass with new gears [Re: 1967dartgt] #2158559
09/21/16 02:47 AM
09/21/16 02:47 AM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
Wheelspeed is your friend smile Unless that's a radial in which case need to do some work smile
Re: Brett's pass with new gears [Re: 1967dartgt] #2158618
09/21/16 10:41 AM
09/21/16 10:41 AM
Hilltown Pa
Hilltown Pa
275 radial.
Re: Brett's pass with new gears [Re: 1967dartgt] #2158626
09/21/16 11:00 AM
09/21/16 11:00 AM
Out West
Out West
I'm no expert, but it looks like it could have used 100# up front before making the gear change. It would probably still be quicker to the 1/8th with the added weight.
