When setting lash what do you guys use #2157504
09/19/16 04:34 PM
09/19/16 04:34 PM
nc
E
earthmover Offline OP
E
nc
On my car is havery the mandrel for my fuel pump to run off the crank I'm afraid I'll break the bolt if I try to turn the motor using the bolt cause it's small..thinking about fixing up a bump button mounted on the fire wall ..what you guys doing to turn the motor over when setting the lash..
Re: When setting lash what do you guys use [Re: earthmover] #2157514
09/19/16 04:41 PM
09/19/16 04:41 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Remote starter switch hooked to the starter relay
Re: When setting lash what do you guys use [Re: earthmover] #2157516
09/19/16 04:43 PM
09/19/16 04:43 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I prefer turning the crank manually with the longest ratcheting breaker-bar I can fit in there. I suppose with the spark plugs out, bumping the ignition would be fairly accurate, but I'd hate to be off. Maybe that's just paranoia, but it's something I don't want to second-guess.
Re: When setting lash what do you guys use [Re: fast68plymouth] #2157519
09/19/16 04:45 PM
09/19/16 04:45 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
^^This^^ Mine has 6' or so cord on it.
Re: When setting lash what do you guys use [Re: fast68plymouth] #2157527
09/19/16 04:50 PM
09/19/16 04:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use a remote button.. I just clip it on the relay..
it has about 3' long wires so I move it around side to
side... I use the open/closed method so its pretty easy..
I do one cyl at a time working from front to back... I
thought about mounting a button but I have enough crap in
the way already
wave
Re: When setting lash what do you guys use [Re: MR_P_BODY] #2157577
09/19/16 05:46 PM
09/19/16 05:46 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
My car has hard wired push buttons mounted on both sides of the car for bumping the motor over. Once you adjust the valves this way you never go back to rotating the motor over with a breaker bar.
Set the intake valve lash when the exhaust valve is beginning to open.
Set the exhaust valve lash when the intake valve is about halfway down on the closing side.
Re: When setting lash what do you guys use [Re: earthmover] #2157584
09/19/16 06:01 PM
09/19/16 06:01 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
iagree
Master, again and still
Re: When setting lash what do you guys use [Re: earthmover] #2157610
09/19/16 06:39 PM
09/19/16 06:39 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I put a bump button on the firewall, unreal how much time it saves.
68 Barracuda Formula S 340
Re: When setting lash what do you guys use [Re: earthmover] #2157638
09/19/16 07:14 PM
09/19/16 07:14 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Bump button on the firewall wired in the starter relay. Can't crank unless it's in park/neutral. I can do mine in 15 minutes.
Doug
Re: When setting lash what do you guys use [Re: earthmover] #2157736
09/19/16 09:34 PM
09/19/16 09:34 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Well, it's official: I've been over-thinking it or being too paranoid! D'oh!!!
Re: When setting lash what do you guys use [Re: fast68plymouth] #2157755
09/19/16 10:01 PM
09/19/16 10:01 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Same here as I do mine by watching the valves as I tap it over. Ron
