quick carb question #2155905
09/16/16 07:20 PM
09/16/16 07:20 PM
own private Idaho
N
ngpSatellite Offline OP
N
own private Idaho
Whats the best medium to soak a carburetor in before a complete rebuild?. 1st time rebuilding one... its not too dirty.... any suggestions would be appreciated.....
Thanks!!
Re: quick carb question [Re: ngpSatellite] #2155932
09/16/16 08:05 PM
09/16/16 08:05 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
I use Chem-Dip
http://www.staples.com/Chem-Dip-Fast-Acting-Professional-Parts-Cleaner-5-gal/product_774852?cid=PS:GooglePLAs:774852&ci_src=17588969&ci_sku=774852&KPID=774852&gclid=COjZ9brxlM8CFUIfhgod6qkDAA
It's pretty expensive for the 5 gallon container. You can buy one gallon cans at parts stores but larger parts don't fit in the can.
Re: quick carb question [Re: Ply72rr] #2155958
09/16/16 09:47 PM
09/16/16 09:47 PM
get a metal pan/bowl at the thrift shop just big enough to set the main body in & pour the soup into the carb bowl. its the internal passages to be cleaned that are critical. you can bristle brush the outsides/venturis etc
Re: quick carb question [Re: ngpSatellite] #2156067
09/17/16 03:32 AM
09/17/16 03:32 AM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
I don't think the newer carb cleaners contain methylene chloride. If it does, be very careful with it. Pretty nasty stuff. Don't get it on you and try not to breath it.
