Please help me understand this fender tag ( 69 SuperBee ) #2152110
09/11/16 03:55 AM
09/11/16 03:55 AM
Big Island ,VA
JC Childress Offline OP
Big Island ,VA
I am looking at this car and would love more info from this fender tag. What I have gathered is its 383 with 4 speed and its T5 in color. I would like to know which wheels came on it, what the rear gear is supposed to be, is it a 18 or 23 spline trans, did they ever come with a grill painted black, is it supposed to have the Ramcharger dual scoops, is it supposed to have the side scoops and anything this may tell. Is it a fairly common car ? Is it rare ? I appreciate any and all help.
If you wanna text me, I'm at 434-665-9541.
Thanks so much.
J.C. Childress (434) 665-9541
Re: Please help me understand this fender tag ( 69 SuperBee ) [Re: JC Childress] #2152782
09/11/16 11:35 PM
09/11/16 11:35 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Yes N96 Ramcharger hood, no way to tell the wheels, 23 spline trans with the 383. The rear axle is 3.55 sure grip with 10" brakes so it will be front disc brakes. No M46 on there for the side scoops.
2 door hardtop tan interior.
Is it rare? Not really, is it cool? Heck yes!!!!
Re: Please help me understand this fender tag ( 69 SuperBee ) [Re: NANKET] #2152957
09/12/16 10:04 AM
09/12/16 10:04 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Disc brakes were not standard with 3:55s.
M46 not coded on 69 Lynch Raod tag.
So we do not know about those two items simply from the tag.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: Please help me understand this fender tag ( 69 SuperBee ) [Re: 69CoronetRT] #2153084
09/12/16 02:59 PM
09/12/16 02:59 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Does the tag ID that the rear end is a 3.55 with 10" drums? If so the only way to get 10'drums on the rear of a Superbee is with disk brakes.
If it just says 3.55 them you are correct.
Re: Please help me understand this fender tag ( 69 SuperBee ) [Re: JC Childress] #2153105
09/12/16 03:36 PM
09/12/16 03:36 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Here's a BS from a WS car we used for documenting radiators with axle packages. It shows A36 with B31.
Seeking:
Re: Please help me understand this fender tag ( 69 SuperBee ) [Re: JC Childress] #2153160
09/12/16 05:20 PM
09/12/16 05:20 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Decoding the 591 code tells me 3.55's with 10" rear brakes and the only wat to get those are front discs. I realize the standard super bee brakes were 11" drums all around.
Re: Please help me understand this fender tag ( 69 SuperBee ) [Re: NANKET] #2153262
09/12/16 08:14 PM
09/12/16 08:14 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
OK...help me understand A36 without B41 or B51 on the BS.
Seeking:
Re: Please help me understand this fender tag ( 69 SuperBee ) [Re: 69CoronetRT] #2153275
09/12/16 08:31 PM
09/12/16 08:31 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1969 b-body A36 axle assembly part numbers are:
xxxx591 = 3.55:1 sure-grip (8-3/4") with 10" rear drums (A36 w/power disc brakes)
xxxx594 = 3.55:1 sure-grip (8-3/4") with 11" rear drums (A36 w/manual or power drum brakes)
the only way to get 10" rear drums on a performance b-body in 1969 is with power disc brakes
Re: Please help me understand this fender tag ( 69 SuperBee ) [Re: JC Childress] #2153286
09/12/16 08:50 PM
09/12/16 08:50 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Thank you for the clarification.
I was wrong on the decode.
Seeking:
Re: Please help me understand this fender tag ( 69 SuperBee ) [Re: 69CoronetRT] #2153345
09/12/16 10:32 PM
09/12/16 10:32 PM
Wisconsin
Big D A12 Offline
Big D A12  Offline
Wisconsin
Does anyone have a 1969 LR tag with the 591 or 589 axle code? I just went through my library and did not find any.
BTW, I think this is a 594 code if you look closely.
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!!
2018 Demon Challenger PY4 A8 Black Hood
2017 Jeep Trail Hawk
2016 Hellcat Challenger PCP A8
1969.5 A12 Super Bee WM21 V1H F6 D21
1969 Coronet RT B5 D32 M46 N96
Re: Please help me understand this fender tag ( 69 SuperBee ) [Re: Big D A12] #2153396
09/12/16 11:36 PM
09/12/16 11:36 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
It does look like 594 - good eyes
Re: Please help me understand this fender tag ( 69 SuperBee ) [Re: JC Childress] #2155488
09/16/16 01:21 AM
09/16/16 01:21 AM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Thanks so much.
f
My 69 Coromet R/T is almost a twin to your car excerpt the 440/18 spline/Dana 60 of course
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
