Please help me understand this fender tag ( 69 SuperBee )
#2152110
09/11/16 03:55 AM
09/11/16 03:55 AM
Posts: 411 Big Island ,VA
JC Childress
Big Island ,VA
I am looking at this car and would love more info from this fender tag. What I have gathered is its 383 with 4 speed and its T5 in color. I would like to know which wheels came on it, what the rear gear is supposed to be, is it a 18 or 23 spline trans, did they ever come with a grill painted black, is it supposed to have the Ramcharger dual scoops, is it supposed to have the side scoops and anything this may tell. Is it a fairly common car ? Is it rare ? I appreciate any and all help.
If you wanna text me, I'm at 434-665-9541.
Thanks so much.
J.C. Childress
(434) 665-9541
Re: Please help me understand this fender tag ( 69 SuperBee )
[Re: NANKET]
#2152957
09/12/16 10:04 AM
09/12/16 10:04 AM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
Disc brakes were not standard with 3:55s. M46 not coded on 69 Lynch Raod tag.
So we do not know about those two items simply from the tag.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: 69CoronetRT]
#2153084
09/12/16 02:59 PM
09/12/16 02:59 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
So we do not know about those two items simply from the tag. Does the tag ID that the rear end is a 3.55 with 10" drums? If so the only way to get 10'drums on the rear of a Superbee is with disk brakes. If it just says 3.55 them you are correct.
[Re: JC Childress]
#2153105
09/12/16 03:36 PM
09/12/16 03:36 PM
69CoronetRT
Harlan, Iowa
Here's a BS from a WS car we used for documenting radiators with axle packages. It shows A36 with B31.
Seeking:
[Re: NANKET]
#2153262
09/12/16 08:14 PM
09/12/16 08:14 PM
69CoronetRT
Harlan, Iowa
Decoding the 591 code tells me 3.55's with 10" rear brakes and the only wat to get those are front discs. I realize the standard super bee brakes were 11" drums all around. OK...help me understand A36 without B41 or B51 on the BS.
Seeking:
[Re: JC Childress]
#2153286
09/12/16 08:50 PM
09/12/16 08:50 PM
69CoronetRT
Harlan, Iowa
Thank you for the clarification. I was wrong on the decode.
Seeking:
[Re: 69CoronetRT]
#2153345
09/12/16 10:32 PM
09/12/16 10:32 PM
Posts: 304 Wisconsin
Big D A12
Wisconsin
Does anyone have a 1969 LR tag with the 591 or 589 axle code? I just went through my library and did not find any.
BTW, I think this is a 594 code if you look closely.
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!! 2018 Demon Challenger PY4 A8 Black Hood 2017 Jeep Trail Hawk 2016 Hellcat Challenger PCP A8 1969.5 A12 Super Bee WM21 V1H F6 D21 1969 Coronet RT B5 D32 M46 N96
[Re: Big D A12]
#2153396
09/12/16 11:36 PM
09/12/16 11:36 PM
Morty426
Sacramento CA
D It does look like 594 - good eyes
[Re: JC Childress]
#2155488
09/16/16 01:21 AM
09/16/16 01:21 AM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
Thanks so much. f My 69 Coromet R/T is almost a twin to your car excerpt the 440/18 spline/Dana 60 of course
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
