HELP PLEASE..... #2153942
09/13/16 08:11 PM
09/13/16 08:11 PM
Cold Canada
demon340owner Offline OP
Cold Canada
I went to the drags the other day with my supposed 550 hp. small block. 1.80 60 ft. 11.92 112 mph.whats going on..
71 demon 3250 lbs with me frame connectors, 4500 flash stall,727 reverse pattern.
340-373 forged internals 13-1 compression W2 heads flow 315-250cfm
1 5 8 headers 28 tire spool..c 14 race fuel mixed 50 50 super unleaded
What am I missing timing @ 32 degrees..
Plese help me I dont know what to do to get my M.P.H.
Thanks alot any info would help.
Re: HELP PLEASE..... [Re: demon340owner] #2153960
09/13/16 08:35 PM
09/13/16 08:35 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
What carb.............
Re: HELP PLEASE..... [Re: demon340owner] #2153963
09/13/16 08:42 PM
09/13/16 08:42 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Do you have a fuel pressure gauge on it?
Re: HELP PLEASE..... [Re: demon340owner] #2153964
09/13/16 08:42 PM
09/13/16 08:42 PM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
What fuel pump and line size?, gear ratio?
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: HELP PLEASE..... [Re: demon340owner] #2153988
09/13/16 09:24 PM
09/13/16 09:24 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
what rpm are you shifting at?
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: HELP PLEASE..... [Re: demon340owner] #2154008
09/13/16 09:57 PM
09/13/16 09:57 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
What gears? What rpm did it launch at? Did you check for wide open throttle?
[image][/image]
Re: HELP PLEASE..... [Re: demon340owner] #2154020
09/13/16 10:12 PM
09/13/16 10:12 PM
P
Porter67 Offline
Porter67  Offline
P
Header change.... quickly.
1 5/8 full length tube headers will not support your 550 hp potential.
Sounds like your currently more like at 425-440hp.
Re: HELP PLEASE..... [Re: Porter67] #2154032
09/13/16 10:29 PM
09/13/16 10:29 PM
Cold Canada
Cold Canada
Wow you guys are fast,I will try to answer everyone.
Carb 650 dp holley 55 power valve 78 jet front 82 rear. fuel pressure I think 7 psi holley blue pump no guage.. Fuel line 3-8 ,I shifted at 6000, and launched at 2000 rpm..Rear gear is 4,10 dana 60 no pinion snubber nosedown almost 10 degrees.
Re: HELP PLEASE..... [Re: demon340owner] #2154037
09/13/16 10:40 PM
09/13/16 10:40 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Carb is way too small. Have you tried different launch/shift points yet?
How do you "think" fuel PSI is 7#, without a gauge??
I assume the motor is fresh? I'd do a leak down test anyway to start at the basic step one and go from there.
There are ALOT of things that make up a good running car. BUT...it only takes one or two seemingly small things to really hurt the performance.
Re: HELP PLEASE..... [Re: demon340owner] #2154043
09/13/16 10:43 PM
09/13/16 10:43 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You need a fuel pressure gauge and the pressure is usually based on the needle n seat size. Bigger = lower pressures and visa versa and a 650 wouldn't be my first choice along w/10 degrees of pinion angle............
Re: HELP PLEASE..... [Re: demon340owner] #2154050
09/13/16 10:49 PM
09/13/16 10:49 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
The headers aren't going to kill that much power. I have been 10.70's in a heavier car with basically same size header .
Sounds like something in the combo is way wrong, making it be a dog.
My heavier car with a 318 runs about like what your seeing, what camshaft, and where did the heads come from?
Even the carb shouldn't kill that motor all that much. Should run well into the 10's easily.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: HELP PLEASE..... [Re: demon340owner] #2154052
09/13/16 10:51 PM
09/13/16 10:51 PM
Spahn Ranch
RMCHRGR Online work
RMCHRGR  Online Work
Spahn Ranch
More RPM, more gear, more carb to start. What intake and cam?
Depending on your cam, 13.1 W2 small block should probably RPM well past 7,000. Deeper rear gear will get you there faster, probably need at least 4.30 or more. Small blocks need gear and converter until you start getting over 400 CI where they produce enough torque.
650 carb is too small especially for your potential RPM, should be at least an 850.
Timing is a little conservative for race fuel, might try 34-36 total?
Also, pinion 10 degrees nose down is too much, should be 4 down, the car is fighting itself off the line which is reflected in your 60 ft.
Maybe a little more info on the chassis? Rear tire size and inflation? Rear springs? Chassis stiffening? Front end setup? Shocks etc?
'71 Duster
'72 Challenger
'17 Ram 1500
Re: HELP PLEASE..... [Re: RMCHRGR] #2154055
09/13/16 10:55 PM
09/13/16 10:55 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Timing has nothing to do with race fuel regards what you are inferring.
I ran a stout W5 combo on 112 that made best power at 32 degrees, tried it everywhere else, 32 was best. Most good, well done heads don't want much timing, no matter the fuel.
The heads on my current car are supposedly very well done( engine masters engine) and also like 32.... I have had them everywhere between 30-38... 32 best power.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: HELP PLEASE..... [Re: B3422W5] #2154061
09/13/16 11:02 PM
09/13/16 11:02 PM
Spahn Ranch
RMCHRGR Online work
RMCHRGR  Online Work
Spahn Ranch
Can you explain why?
'71 Duster
'72 Challenger
'17 Ram 1500
Re: HELP PLEASE..... [Re: RMCHRGR] #2154067
09/13/16 11:09 PM
09/13/16 11:09 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Like I said above, a good head doesn't need as much timing as a bad head. A very good combustion chamber contributes to the fuel getting burned quicker and more efficiently.
I gave two examples of heads I have had/ have( both with excellent chambers) that make peak power with 32 degrees timing and completely different fuels.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: HELP PLEASE..... [Re: demon340owner] #2154122
09/14/16 12:14 AM
09/14/16 12:14 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
1.80 60 ft., Your bogging big time. It may not feel like it but you are. Your mph is good for a 11.75. Your not getting out of hole, fix that first. Timing needs increased to more like 34* to 36. Test it to be sure. Carb needs some tune as well for sure. All just common stuff for a new combo, it will come around if it was truly dynoed at 550 hp. Your 4500 stall speed is low for a sb as well with that hp.
Re: HELP PLEASE..... [Re: Sport440] #2154132
09/14/16 12:24 AM
09/14/16 12:24 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Originally Posted By Sport440
1.80 60 ft., Your bogging big time. It may not feel like it but you are. Your mph is good for a 11.75. Your not getting out of hole, fix that first. Timing needs increased to more like 36 to 38*. Carb needs some tune as well for sure. All just common stuff for a new combo, it will come around if it was truly dynoed at 550 hp
Lol.... Mph is WAY, WAY off. A 13 to 1 370 inch motor with 300cfm heads should run 120 falling out of a tree with nothing going correctly. Even with a doggy 60 foot the car should still make way more mph than 112. It's likely a lot of little things, but even if running the same timing it made 550 on the Dyno with( which I would assume is the starting point) something else is super out of whack that isn't a simple tweak. It isn't making much over 400 horse based on 112 at that weight.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: HELP PLEASE..... [Re: B3422W5] #2154138
09/14/16 12:38 AM
09/14/16 12:38 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Yes, MPH is way off as well. But hey if it cant get going till 100 ft + out its not going to get the mph the hp should reflect.
At 3250 112 is more like 450hp. I would like to see the mph Split between the 1/8th and the 1/4 Can you post that OP. Should be around 24 mph difference.
Re: HELP PLEASE..... [Re: Sport440] #2154150
09/14/16 12:52 AM
09/14/16 12:52 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
My motor made 477 at engine masters. With a bigger solid cam..... now has a smaller hydralic cam. I have been almost 113.5 At 3415 pounds with power steering and other stock accessories. Guess based on your calculations I have got everything out of this thing it's going to get. I honestly thought about 30-50 horse are unaccounted for( after power robbing accessories are accounted for) was hoping this thing would go 116-117.
Btw, the bad 60 is going to effect ET much more than mph. Much more. I have a buddy who has a 4400 pound Charger with the 475 horse hemi. It runs 110+ mph at that weight and the 60 is as bad or worse than the OP.
I remember doing a huge wheel stand at Norwalk a few years back. Otherwise normal pass that day was 9.95 ish at 133.5/134mph. I lifted an instant when the car landed, ran 10.96 but it still ran almost 130 on that pass. Mph takes power, ET takes a lot of stuff. The OP isn't making any power.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: HELP PLEASE..... [Re: demon340owner] #2154464
09/14/16 04:08 PM
09/14/16 04:08 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Right up front I apologize if this offends you, but make sure the carb is opening fully when the gas pedal is fully depressed. Happens more than you think, what is the saying? "Don't ask me how I know..." whistle
