Re: HELP PLEASE.....
[Re: demon340owner]
#2153964
09/13/16 08:42 PM
09/13/16 08:42 PM
Posts: 860 lancaster,california
johnnycuda
What fuel pump and line size?, gear ratio?
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: Porter67]
#2154032
09/13/16 10:29 PM
09/13/16 10:29 PM
Posts: 9 Cold Canada
demon340owner
Cold Canada
Wow you guys are fast,I will try to answer everyone. Carb 650 dp holley 55 power valve 78 jet front 82 rear. fuel pressure I think 7 psi holley blue pump no guage.. Fuel line 3-8 ,I shifted at 6000, and launched at 2000 rpm..Rear gear is 4,10 dana 60 no pinion snubber nosedown almost 10 degrees.
[Re: demon340owner]
#2154037
09/13/16 10:40 PM
09/13/16 10:40 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
Carb is way too small. Have you tried different launch/shift points yet?
How do you "think" fuel PSI is 7#, without a gauge??
I assume the motor is fresh? I'd do a leak down test anyway to start at the basic step one and go from there.
There are ALOT of things that make up a good running car. BUT...it only takes one or two seemingly small things to really hurt the performance.
[Re: demon340owner]
#2154043
09/13/16 10:43 PM
09/13/16 10:43 PM
Thumperdart
State of confusion
You need a fuel pressure gauge and the pressure is usually based on the needle n seat size. Bigger = lower pressures and visa versa and a 650 wouldn't be my first choice along w/10 degrees of pinion angle............
[Re: demon340owner]
#2154050
09/13/16 10:49 PM
09/13/16 10:49 PM
Posts: 11,718 Portage,michigan
B3422W5
Portage,michigan
The headers aren't going to kill that much power. I have been 10.70's in a heavier car with basically same size header . Sounds like something in the combo is way wrong, making it be a dog. My heavier car with a 318 runs about like what your seeing, what camshaft, and where did the heads come from? Even the carb shouldn't kill that motor all that much. Should run well into the 10's easily.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: demon340owner]
#2154052
09/13/16 10:51 PM
09/13/16 10:51 PM
Posts: 1,893 Spahn Ranch
RMCHRGR
Spahn Ranch
More RPM, more gear, more carb to start. What intake and cam?
Depending on your cam, 13.1 W2 small block should probably RPM well past 7,000. Deeper rear gear will get you there faster, probably need at least 4.30 or more. Small blocks need gear and converter until you start getting over 400 CI where they produce enough torque.
650 carb is too small especially for your potential RPM, should be at least an 850.
Timing is a little conservative for race fuel, might try 34-36 total?
Also, pinion 10 degrees nose down is too much, should be 4 down, the car is fighting itself off the line which is reflected in your 60 ft.
Maybe a little more info on the chassis? Rear tire size and inflation? Rear springs? Chassis stiffening? Front end setup? Shocks etc?
'71 Duster '72 Challenger '17 Ram 1500
[Re: RMCHRGR]
#2154055
09/13/16 10:55 PM
09/13/16 10:55 PM
B3422W5
Portage,michigan
Maybe a little more info on the chassis? Rear tire size and inflation? Rear springs? Chassis stiffening? Front end setup? Shocks etc? Timing has nothing to do with race fuel regards what you are inferring. I ran a stout W5 combo on 112 that made best power at 32 degrees, tried it everywhere else, 32 was best. Most good, well done heads don't want much timing, no matter the fuel. The heads on my current car are supposedly very well done( engine masters engine) and also like 32.... I have had them everywhere between 30-38... 32 best power.
[Re: B3422W5]
#2154061
09/13/16 11:02 PM
09/13/16 11:02 PM
RMCHRGR
Spahn Ranch
Timing has nothing to do with race fuel regards what you are inferring. Can you explain why?
[Re: RMCHRGR]
#2154067
09/13/16 11:09 PM
09/13/16 11:09 PM
B3422W5
Portage,michigan
Timing has nothing to do with race fuel regards what you are inferring. Can you explain why? Like I said above, a good head doesn't need as much timing as a bad head. A very good combustion chamber contributes to the fuel getting burned quicker and more efficiently. I gave two examples of heads I have had/ have( both with excellent chambers) that make peak power with 32 degrees timing and completely different fuels.
[Re: demon340owner]
#2154122
09/14/16 12:14 AM
09/14/16 12:14 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
1.80 60 ft., Your bogging big time. It may not feel like it but you are. Your mph is good for a 11.75. Your not getting out of hole, fix that first. Timing needs increased to more like 34* to 36. Test it to be sure. Carb needs some tune as well for sure. All just common stuff for a new combo, it will come around if it was truly dynoed at 550 hp. Your 4500 stall speed is low for a sb as well with that hp.
[Re: Sport440]
#2154132
09/14/16 12:24 AM
09/14/16 12:24 AM
B3422W5
Portage,michigan
1.80 60 ft., Your bogging big time. It may not feel like it but you are. Your mph is good for a 11.75. Your not getting out of hole, fix that first. Timing needs increased to more like 36 to 38*. Carb needs some tune as well for sure. All just common stuff for a new combo, it will come around if it was truly dynoed at 550 hp Lol.... Mph is WAY, WAY off. A 13 to 1 370 inch motor with 300cfm heads should run 120 falling out of a tree with nothing going correctly. Even with a doggy 60 foot the car should still make way more mph than 112. It's likely a lot of little things, but even if running the same timing it made 550 on the Dyno with( which I would assume is the starting point) something else is super out of whack that isn't a simple tweak. It isn't making much over 400 horse based on 112 at that weight.
[Re: B3422W5]
#2154138
09/14/16 12:38 AM
09/14/16 12:38 AM
Sport440
Canton, Ohio
1.80 60 ft., Your bogging big time. It may not feel like it but you are. Your mph is good for a 11.75. Your not getting out of hole, fix that first. Timing needs increased to more like 36 to 38*. Carb needs some tune as well for sure. All just common stuff for a new combo, it will come around if it was truly dynoed at 550 hp Lol.... Mph is WAY, WAY off. A 13 to 1 370 inch motor with 300cfm heads should run 120 falling out of a tree with nothing going correctly. Even with a doggy 60 foot the car should still make way more mph than 112. It's likely a lot of little things, but even if running the same timing it made 550 on the Dyno with( which I would assume is the starting point) something else is super out of whack that isn't a simple tweak. It isn't making much over 400 horse based on 112 at that weight. Yes, MPH is way off as well. But hey if it cant get going till 100 ft + out its not going to get the mph the hp should reflect. At 3250 112 is more like 450hp. I would like to see the mph Split between the 1/8th and the 1/4 Can you post that OP. Should be around 24 mph difference.
[Re: Sport440]
#2154150
09/14/16 12:52 AM
09/14/16 12:52 AM
B3422W5
Portage,michigan
1.80 60 ft., Your bogging big time. It may not feel like it but you are. Your mph is good for a 11.75. Your not getting out of hole, fix that first. Timing needs increased to more like 36 to 38*. Carb needs some tune as well for sure. All just common stuff for a new combo, it will come around if it was truly dynoed at 550 hp Lol.... Mph is WAY, WAY off. A 13 to 1 370 inch motor with 300cfm heads should run 120 falling out of a tree with nothing going correctly. Even with a doggy 60 foot the car should still make way more mph than 112. It's likely a lot of little things, but even if running the same timing it made 550 on the Dyno with( which I would assume is the starting point) something else is super out of whack that isn't a simple tweak. It isn't making much over 400 horse based on 112 at that weight. Yes, MPH is way off as well. But hey if it cant get going till 100 ft + out its not going to get the mph the hp should reflect. At 3250 112 is more like 450hp. I would like to see the mph Split between the 1/8th and the 1/4 Can you post that OP. Should be around 24 mph difference. My motor made 477 at engine masters. With a bigger solid cam..... now has a smaller hydralic cam. I have been almost 113.5 At 3415 pounds with power steering and other stock accessories. Guess based on your calculations I have got everything out of this thing it's going to get. I honestly thought about 30-50 horse are unaccounted for( after power robbing accessories are accounted for) was hoping this thing would go 116-117. Btw, the bad 60 is going to effect ET much more than mph. Much more. I have a buddy who has a 4400 pound Charger with the 475 horse hemi. It runs 110+ mph at that weight and the 60 is as bad or worse than the OP. I remember doing a huge wheel stand at Norwalk a few years back. Otherwise normal pass that day was 9.95 ish at 133.5/134mph. I lifted an instant when the car landed, ran 10.96 but it still ran almost 130 on that pass. Mph takes power, ET takes a lot of stuff. The OP isn't making any power.
