Re: 4 speed stuck in 4th gear
[Re: 7812845]
#2153303
09/12/16 09:15 PM
09/12/16 09:15 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
well,, it's up on a lift.
Is it the shifter that is jammed or the transmission?
[Re: Supercuda]
#2153347
09/12/16 10:34 PM
09/12/16 10:34 PM
Posts: 444 Loma Linda, MO
7812845
Loma Linda, MO
2020 RAM Longhorn 4x4 2022 Jeep Grand Cherokee Overland
[Re: 7812845]
#2153378
09/12/16 11:10 PM
09/12/16 11:10 PM
Supercuda
About to go away
About to go away
up yours
that sux, but at least you aren't on the side of the road wondering.
[Re: 7812845]
#2153455
09/13/16 12:56 AM
09/13/16 12:56 AM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
I don't understand how a worn-out 1st synchro keep you from shifting 4-3? Speaking of "on the side of the road wondering": Way back around '85, I had a similar feeling develop in my A-833 about 2 miles from home (at midnight with rain coming, of course). Finally it stuck "between" 3 & 4 and the car wouldn't move at all. Hiked home, drove back with a toolbox, got underneath and moved the shift arm to 4, N, 3... no resistance and the driveshaft stayed locked. Then of course the clouds opened up and within seconds I was lying in an inch of water. Gave up for the night! Next day had it towed home, pulled the side cover, and found that the neck had snapped off the 3/4 shift fork. Popped in a new fork, back in business.
[Re: 7812845]
#2153475
09/13/16 01:33 AM
09/13/16 01:33 AM
Supercuda
About to go away
About to go away
up yours
My 64 300's original shifter was very worn out when I bought, found out when I was at a friend's wedding reception, stuck in first. Turns out the forks in the shifter housing were so wore out it'd let the shifter handle slip in between them and hang up. So there I am in my dress blues unhanging my shifter so I can give a girl a ride home. I'm sure she was impressed.
I ended up putting an Indy shift in at a later time.
[Re: Supercuda]
#2153550
09/13/16 09:59 AM
09/13/16 09:59 AM
7812845
Loma Linda, MO
I'll know more later today when the tranny is removed and put on a bench to get a better look. From what I've been told there is a lot of brass in places it shouldn't be. There might be more damage to synchronizers that couldn't be seen on first inspection. I'm just glad I was real close to my mechanic's shop when this happened.
[Re: 7812845]
#2153818
09/13/16 05:05 PM
09/13/16 05:05 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
I'll know more later today when the tranny is removed and put on a bench to get a better look. From what I've been told there is a lot of brass in places it shouldn't be. There might be more damage to synchronizers that couldn't be seen on first inspection. I'm just glad I was real close to my mechanic's shop when this happened. What does he mean by "there is a lot of brass in places it shouldn't be" ??? The brass is part of the syncro assemblies, the syncros are inside the transmission and in the oil ... the only oil source in the transmission by the way ... the oil circulates inside the ENTIRE transmission, the only place that it should not be is on the outside of the transmission ?????
[Re: 7812845]
#2153829
09/13/16 05:24 PM
09/13/16 05:24 PM
Posts: 25,791 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I've seen transmissions stuck in high before. What usually happens is the input shaft dog teeth will wear notches in the front of the 3-4 sleeve from the constant on/off the throttle, after a time the dog teeth on the input shaft will lock into the notches and will prevent the sleeve from disengaging the dog teeth.
[Re: John_Kunkel]
#2154726
09/14/16 10:10 PM
09/14/16 10:10 PM
7812845
Loma Linda, MO
I've seen transmissions stuck in high before. What usually happens is the input shaft dog teeth will wear notches in the front of the 3-4 sleeve from the constant on/off the throttle, after a time the dog teeth on the input shaft will lock into the notches and will prevent the sleeve from disengaging the dog teeth. Bingo, this is exactly what has happened. 3-4 synchronizer is the brass that is in the transmission. Just got thru looking at it and it's the problem. I'll be calling Brewers in a couple days.
