Another burnt pushrod! #2152497
09/11/16 07:03 PM
09/11/16 07:03 PM
gregsdart Offline OP
Right after the trans brake quit, I loaded up and came home, thinking the motor was in good shape. As I pulled up onto the lift it started to pop and miss, then REALLY got noisy! Same # 2 intake, worn so bad the lash cap was off, metal every where. I checked both pushrods on that cylinder, BONE DRY! I am supposed to have pushrod oiling. I spent a lot of $$ for Isky EZ rolls, asked for pushrod oiling, and for some reason don't have it.
The spray bars kept the other fourteen alive, but there must not be any oil directed properly at that number two intake, and maybe #1 intake as well, which failed last time out. So, the phone calls will be going out tomorrow, hopefully I will get some answers.
Re: Another burnt pushrod! [Re: gregsdart] #2152512
09/11/16 07:26 PM
09/11/16 07:26 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Man I really hate to see you have these issues on a system that can work sooooo great with the factory oiling. I'm going to say I have 1000 plus runs between 8.40 and 9.10 with the stock non-pushrod oiling set-up. Never once hurt a pushrod or a lifter. I love simplicity. Only issue I had was to much oil so I put a restrictor in the back of the block and ran the heck out of it. I hope your luck turns around
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Another burnt pushrod! [Re: gregsdart] #2152517
09/11/16 07:30 PM
09/11/16 07:30 PM
I figure my luck has to turn soon, I am running out of stuff to fix blush
Re: Another burnt pushrod! [Re: gregsdart] #2152779
09/11/16 11:33 PM
09/11/16 11:33 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
T&D or Jesel rockers?
Re: Another burnt pushrod! [Re: fbs63] #2152846
09/12/16 12:57 AM
09/12/16 12:57 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
What block do you run Greg?
Todd
Re: Another burnt pushrod! [Re: gregsdart] #2152924
09/12/16 07:57 AM
09/12/16 07:57 AM
Megablock, cast 1998?, bushed lifter bores, .060 hole drilled in bushing into the oil galley, Jesel rockers, Mike Jones inverted flank roller, .867 lift, supposed to be easy on parts due to very long lash ramps. Springs are PAC 1228 in at 2.035, advertised numbers say about 320 on the seat, 825 open at net lift .
Re: Another burnt pushrod! [Re: gregsdart] #2152934
09/12/16 09:00 AM
09/12/16 09:00 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Do your ez rolls have the EDM oiling hole as well?
Re: Another burnt pushrod! [Re: gregsdart] #2152944
09/12/16 09:35 AM
09/12/16 09:35 AM
I made the mistake of not looking! I asked for pushrod oiling, I will know for certain by afternoon. Can they be fixed if I got the wrong ones?
Re: Another burnt pushrod! [Re: gregsdart] #2152953
09/12/16 10:01 AM
09/12/16 10:01 AM
USA
B3RE Offline
B3RE  Offline
USA
Hey Greg,
Sorry to hear about all the issues. I realize you were supposed to have pushrod oiling, but the spray bars should be adequate, if there is enough oil volume. Do you know the spray hole size and quantity, and the restrictor size feeding the head?
I had a problem with number 1 and number 2 intake rockers on a Hemi not getting enough oil from the spray bar and it was turning the roller and valve tip blue from heat. When I calculated the total area of the spray bar holes, and compared them to the restrictor, they were exactly the same. Considering that pressure will drop over distance, it didn't have enough volume to maintain pressure at the furthest point from the source, so it just dribbled oil and didn't actually spray. I'm going to assume your spray bars are fed from the rear of the block, so numbers 1 and 2 are furthest from the source, and may need a little more volume to get a good spray on the adjusters. It's worth a look.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: Another burnt pushrod! [Re: gregsdart] #2152994
09/12/16 11:45 AM
09/12/16 11:45 AM
Pictures of the lifters. There is a hole above each side of the axle, about .043. They are low enough that they are exposed about 3/4 of the time below the lifter bore.
Re: Another burnt pushrod! [Re: B3RE] #2152998
09/12/16 11:53 AM
09/12/16 11:53 AM
Originally Posted By B3RE
Hey Greg,
Mike, I think you have something there. I restricted those fittings on the outside of the valve covers a long time ago because I have always run pushrod oiling as well, and that may well be why there was no problem until now when I went to the Isky roller lifters. There is no large hole next to the oil galley area like the Comp lifters.
Re: Another burnt pushrod! [Re: gregsdart] #2153001
09/12/16 12:03 PM
09/12/16 12:03 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
How does the oil get from your .060 hole in the bushing into the slot on the lifter body?
Unless I'm missing something, this really doesn't look like it's going to provide proper oiling on a mopar.
I would much rather see a full diameter oil band on the lifter body, that's getting pressure from the feed hole 100% of the time, then have edge orifices above the band in line with the axles.
On the motors I've done with spray bar oiling, I have one .060 restrictor per side.
Re: Another burnt pushrod! [Re: gregsdart] #2153008
09/12/16 12:14 PM
09/12/16 12:14 PM
USA
B3RE Offline
B3RE  Offline
USA
Hey Greg,
You will still need a certain amount of restriction to keep from flooding the top end with oil, but it might just need opened up another .010" or so. I would try priming the motor with a drill, and keep opening the restrictor until it gets oil on all the adjusters. That should equate to adequate oiling at idle, and as long as the oil pressure doesn't drop off on top end, you should be good to go.
If it drops off at higher rpm, you might have to reduce the size of the spray bar holes to reduce pressure loss, but I doubt you will.
Mike Beachel
Re: Another burnt pushrod! [Re: gregsdart] #2153012
09/12/16 12:17 PM
09/12/16 12:17 PM
USA
B3RE Offline
B3RE  Offline
USA
That hole looks like it is only meant to oil the axle. I don't see that being a feed for pushrod oiling.
Mike Beachel
Re: Another burnt pushrod! [Re: fast68plymouth] #2153017
09/12/16 12:25 PM
09/12/16 12:25 PM
USA
B3RE Offline
B3RE  Offline
USA
.060" should be about right, but it depends on how many holes are in the spray bar, and how much area they have bleeding off pressure.
I had to go from .040" to .060" to get oil spraying at the front of the spray bar, and that was with only four .020" holes in the bar. More holes will bleed more pressure with a given area (diameter).
Mike Beachel
Re: Another burnt pushrod! [Re: fast68plymouth] #2153056
09/12/16 02:02 PM
09/12/16 02:02 PM
On some of the Comp Cams roller lifters I used, the oil hole on the lifter was right in line and fed directly from the oil galley, which was too much oil through the pushrods, according to Brian at IMM? I bought lifters from him, Comp again, but with feed holes ninety degrees (no longer directly exposed) to the .060 hole in my bushings. Everything worked fine. I do remember oil in the pushrods, so it was flowing around the lifter body and entering the feed hole and up through the pushrod. It is pretty obvious now that I got lifters without oiling, and I will test the spraybar system and check to see what I put in there for restrictors.
The Isky EZ roll lifters were drop shipped to me directly from Isky, and they sent the wrong ones. Brian told me to send them back to Isky and he would get this taken care of. That is great customer service. Thanks Brain!! up
Re: Another burnt pushrod! [Re: gregsdart] #2153066
09/12/16 02:28 PM
09/12/16 02:28 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
maybe it's me but I don't see any hole for pushrod oil?
Re: Another burnt pushrod! [Re: gregsdart] #2153070
09/12/16 02:38 PM
09/12/16 02:38 PM
So. Burlington, Vt.
So. Burlington, Vt.
..... but with feed holes ninety degrees (no longer directly exposed) to the .060 hole in my bushings. Everything worked fine.
That's the correct way to have it....... And like you said, it worked fine.
With the lifters in the pic, even if they have a hole from the slot that feeds the pushrods..... How does the oil get into the slot?
The smooth part of the lifter body just blocks off the hole in the bushing.
The way those lifters are set up, they don't do a good job of oiling the roller either..... For the same reason. No way to get the pressurized oil into the slot.
Unless, as I stated previously...... I'm missing something.
I'd send 'em back......they're not what you wanted..... And it's not like they're cheap either.
Edit: I just blew the pic up and finally saw the roller oiling holes.
Looks like that's just splash oiling to me.
I'm no engineer, but that seems like a fairly highly stressed area of the lifter body to drill an extra hole into........ Right above the axle.
Re: Another burnt pushrod! [Re: fast68plymouth] #2153078
09/12/16 02:48 PM
09/12/16 02:48 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Good to hear you got it figured out, and it seems like the carnage is minimal. Sorry you have to clean all the debris. At least as you said, the valve sealing numbers are good. BIR at the end of the month? 🙂
Re: Another burnt pushrod! [Re: gregsdart] #2153083
09/12/16 02:57 PM
09/12/16 02:57 PM
AndyF Online content
AndyF  Online Content
I got pushrod oiling lifters from Crower years back and they were drilled wrong. The hole for the pushrod came out of the gallery area and flooded the top end. Crower wouldn't take them back or fix them which is one reason why I stopped using Crower parts.
I figured out much later how I could've fixed the lifters but water under the bridge. From what I've seen over the years the best way to provide oil to the pushrods is to pull oil from the clearance around the lifter. That way the clearance area acts as a restrictor and limits the oil to the top end.
Just a few weeks back I got a set of the new Sportsman roller lifters from Comp which are advertised as pushrod oiling. But when I opened the box I couldn't see any evidence of pushrod oiling. I talked to Comp and they agreed that their Mopar lifters do not oil the pushrod and that the catalog information was misleading.
