AC trouble NOW WORKING #2149673
09/07/16 03:28 PM
09/07/16 03:28 PM
Stockholm, Sweden
MrSixpack Offline OP
Stockholm, Sweden
1966 Chrysler 300 with a 383.
Just restored the ac compressor with new rubber seals and gaskets.
Filled it up to day with the help of my friend and ac expert(not expert on old car ac´s)
It is leak free and seems to be fine.
But it´s not blow any cold air, the inlet is pipe is cold and the outlet pipe is hot.
He thought it´s a valve problem?
What could it be??
Thanks.
1970 Super Stock Challenger ex. Paul Rossi
1968 Dodge Dart GT 340
1968 Dodge Charger /6 3 speed manual
1966 Chrysler 300 Loaded
1968 Dodge Charger R/T 440
1968 Mini Cooper
Re: AC trouble [Re: MrSixpack] #2149746
09/07/16 05:19 PM
09/07/16 05:19 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Is it blowing air from the dash registers when in the A/C mode?
Re: AC trouble [Re: MrSixpack] #2149753
09/07/16 05:31 PM
09/07/16 05:31 PM
Washington/Las Vegas
1971 Gran Coupe Offline
Water valve may be defective or in the open mode allowing hot coolant to over-ride the ac.
Re: AC trouble [Re: MrSixpack] #2150172
09/08/16 04:50 AM
09/08/16 04:50 AM
Stockholm, Sweden
Stockholm, Sweden
Yes it´s blowing air in AC mode.
I was thinking of the vale under the dash on the passenger side.
But how do I check that?
I have checked that the actuator wire is moving whit the heat switch and it moves. but could it be some internal leak in it?
http://www.moparmall.com/Heater-Water-Valve-for-1960-1966-MoPar-C-Body-Im-p/816-xxx.htm
1968 Mini Cooper
Re: AC trouble [Re: MrSixpack] #2150198
09/08/16 08:16 AM
09/08/16 08:16 AM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
What could it be??
Thanks.
As in water valve or expansion valve? Gauge pressures will tell you if it's an expansion valve problem.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: AC trouble [Re: MrSixpack] #2150387
09/08/16 02:54 PM
09/08/16 02:54 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Does it still have the EPR valve? What freon are you using?
http://www.classicautoair.com/techtalk/r...ar-to-134a.html
Re: AC trouble [Re: MrSixpack] #2150506
09/08/16 06:06 PM
09/08/16 06:06 PM
P
Paul_Fancsali Offline
P
EPR on a RV2 comp or expansion valve hit it with a rubber mallet and see if it goes cold
Re: AC trouble [Re: MrSixpack] #2150849
09/09/16 04:01 AM
09/09/16 04:01 AM
Stockholm, Sweden
Stockholm, Sweden
Okey, I drove the car to work again today and I had the windows down because it was hot outside.
And I thought I will try the AC again, and now I had a thermometer with me in the car.
I put the sensor in the outlet and had 87F, then I put the windows up and put on the AC, after 5 minutes it was blowing 57F.
We can only use R134 here in Sweden so I think it´s pretty good for what it is.
So with new oil in the system and fully charged the valves are unstucked :-)
The system has been out of use for 10-15 years so finally it works.
Thanks for all your help guys :-)
1968 Mini Cooper
Re: AC trouble [Re: MrSixpack] #2150935
09/09/16 12:06 PM
09/09/16 12:06 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Re: AC trouble [Re: MrSixpack] #2150951
09/09/16 12:24 PM
09/09/16 12:24 PM
None
71rm23 Offline
71rm23  Offline
None
MrSix-In general, you should see 20-25* difference inside from outside air. With that, I'd say you're golden. Glad it's working for you
