Front suspension question #2148182
09/05/16 07:01 PM
09/05/16 07:01 PM
in front of the computer
8
80arrow Offline OP
80arrow  Offline OP
I'm thinking of maybe going to a tubular k member, coil over front with a rack and pinion. Will I get enough travel out of it for weight transfer? I'm running a torsion bar front with Santoff's front shocks with them 1/2 turn from full tight on rebound to keep the front from going 3 feet in the air. Running Calvert springs, cal-tracs, and Menscar rear shocks. So far it's only 60'ing 1.27-29. Car weighs 3520 with me in it, planning on trying to take 300lbs out this winter. If I need to provide more info let me know.
Re: Front suspension question [Re: 80arrow] #2148544
09/06/16 02:47 AM
09/06/16 02:47 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
A car that 60fts that hard or harder needs little travel
Re: Front suspension question [Re: 80arrow] #2150076
09/08/16 12:20 AM
09/08/16 12:20 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I don't have a problem with mine. I run a afco 5" stroke front coil over.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Front suspension question [Re: 80arrow] #2150111
09/08/16 01:09 AM
09/08/16 01:09 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
That will be a really good start to dropping the weight. You might want a stiffer coil spring and/or lower travel shock to keep the front end down after pulling that much weight out.
[image][/image]
Re: Front suspension question [Re: 80arrow] #2150152
09/08/16 02:29 AM
09/08/16 02:29 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Depending on what K you go with make sure a factory length shock will work. A 5" stroke didn't work for me, from ride hieght I only had about 2.5" to go
Re: Front suspension question [Re: 80arrow] #2150212
09/08/16 09:23 AM
09/08/16 09:23 AM
gregsdart Offline
gregsdart  Offline
Clint, any way you can go chrome moly and struts? That would be the ultimate, if it fits your plan for the car.
Re: Front suspension question [Re: gregsdart] #2150725
09/08/16 11:21 PM
09/08/16 11:21 PM
8
80arrow Offline OP
80arrow  Offline OP
Greg, I was thinking of a Bob's Profab front end. It would be molly, a rack, and stock length shocks with coil springs. I'm not sure if struts would work in my class. Supposed to be "stock" type suspension.
Re: Front suspension question [Re: 80arrow] #2150726
09/08/16 11:22 PM
09/08/16 11:22 PM
8
80arrow Offline OP
80arrow  Offline OP
Thank you Monte, that's what I was thinking but wanted some confirmation from some one who knows.
