Re: Front suspension question
[Re: 80arrow]
#2150076
09/08/16 12:20 AM
09/08/16 12:20 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I don't have a problem with mine. I run a afco 5" stroke front coil over.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 80arrow]
#2150111
09/08/16 01:09 AM
09/08/16 01:09 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
That will be a really good start to dropping the weight. You might want a stiffer coil spring and/or lower travel shock to keep the front end down after pulling that much weight out.
[image][/image]
[Re: gregsdart]
#2150725
09/08/16 11:21 PM
09/08/16 11:21 PM
Posts: 814 in front of the computer
80arrow
Clint, any way you can go chrome moly and struts? That would be the ultimate, if it fits your plan for the car. Greg, I was thinking of a Bob's Profab front end. It would be molly, a rack, and stock length shocks with coil springs. I'm not sure if struts would work in my class. Supposed to be "stock" type suspension.
