Factory Defect? #214907
02/05/09 11:23 AM
02/05/09 11:23 AM
minnesota
Kirby Offline OP
Kirby  Offline OP
minnesota
So I was working on my 70 Challenger RT/SE clone last night, and it struck me that there is no spare tire hold down brackets welded in place. It was originally a 318/904/column shift car. I am absolutely positive that the pan has never been replace, and there is no signs of the brackets being cut out. I had the trunk sand blasted- so I'd be able to tell if either the pan was replaced, or any grinding to remove the brackets. Is this just another example of a "friday" built car, just sloppy manufacturing and a mistake- or did some cars not have them due to the way they were ordered (doesn't make sense) I think its just an error? Thought it was interesting.
Re: Factory Defect? [Re: Kirby] #214908
02/05/09 05:16 PM
02/05/09 05:16 PM
minnesota
Kirby Offline OP
Kirby  Offline OP
minnesota
Anyone?
Re: Factory Defect? [Re: Kirby] #214909
02/05/09 05:26 PM
02/05/09 05:26 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I don't have much information for you but I always thought that even if you didn't order a spare tire, you still got a rim mounted in the trunk. I would think that all cars would have had the spare tire hold downs.
Re: Factory Defect? [Re: Kirby] #214910
02/05/09 05:29 PM
02/05/09 05:29 PM
WI
RestoRick Offline
RestoRick  Offline
WI
Here's a picture of Tony D'Agostino's Challenger he
posted awhile back...
same missing spare tire bracket; yes, presumably a factory error.
Rick
Re: Factory Defect? [Re: RestoRick] #214911
02/05/09 07:02 PM
02/05/09 07:02 PM
minnesota
Kirby Offline OP
Kirby  Offline OP
minnesota
Thanks Rick- I thought there was a debate in the past about this. Mine is by no means a survivor- but I am certain that there never was one in place- and the pan is original. I thought it was funny that I never noticed it and I've been working on it since october! Tony and I should compare build dates- and see if there is any connection.
Re: Factory Defect? [Re: RestoRick] #214912
02/06/09 11:02 AM
02/06/09 11:02 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Rick
is that a convertible in that pic ? would the tire be mounted in the middle still on a 'vert ? I know 68 - 7- b bodies the spare was located elsewhere from hardtop/coupes ???
Re: Factory Defect? [Re: JohnRR] #214913
02/06/09 11:10 AM
02/06/09 11:10 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Hard top E-bodies spare tire brackets have a bend, they install at the front on the flat & up over the raised lip.
E-Body 'verts have a flat bracket that mounts to the rear of the lip on the flat section.
Re: Factory Defect? [Re: Alaskan_TA] #214914
02/06/09 12:38 PM
02/06/09 12:38 PM
WI
RestoRick Offline
RestoRick  Offline
WI
Yes... convertible like this:
Re: Factory Defect? [Re: burdar] #214915
02/06/09 01:41 PM
02/06/09 01:41 PM
St. Louis, Mo
3
318 Stroker Online content
318 Stroker  Online Content
St. Louis, Mo
There was no provision for ordering a spare tire on an E-body. You had no choice, it came with one whether you wanted it or not...
Re: Factory Defect? [Re: 318 Stroker] #214916
02/06/09 02:42 PM
02/06/09 02:42 PM
Mass
Mike Mancini Offline
Mass
I do not believe that to be true. Code W07 reads "Omit Spare"
Whether this selection also omited bracketry, I do not know.
Do either cars have this code on the broadcast sheet or fender tag?
Michael L. Mancini
American Muscle Car Restorations, Inc.
65 Foliage Drive
N. Kingstown, RI
Premium Quality Restoration Services for Hi-Performance & Classic Automobiles. OE Specialists.
Instrument Specialties, Inc
www.instrument-specialties.com
www.manciniresto.com
www.performancecargraphics.com
Re: Factory Defect? [Re: Mike Mancini] #214917
02/06/09 03:22 PM
02/06/09 03:22 PM
WI
RestoRick Offline
RestoRick  Offline
WI
Interesting...
maybe Tony can check his sheet...
I know he has it handy; we were discussing info on it a couple days ago.
Rick
edit: just sent him a note...
Re: Factory Defect? [Re: RestoRick] #214918
02/06/09 03:36 PM
02/06/09 03:36 PM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
hi all
i have a spare code W34 = collaspible spare
my spd is 226 = feb 26th 1970
the car is F8 green, but does have the rad support blackout
also i had posted on another thread months ago (maybe rick kept that one too) that on the drivers side door jamb the outward facing screw for the rubber/steel 1/4 window to door jamb escutchin was never drilled
feb 26 1970 was a thurs, maybe it was really built on that friday when workers called in sick????????
weird
Re: Factory Defect? [Re: TONY_DAGOSTINO] #214919
02/06/09 04:04 PM
02/06/09 04:04 PM
WI
RestoRick Offline
RestoRick  Offline
WI
yup... lol
Re: Factory Defect? [Re: RestoRick] #214920
02/11/09 02:07 PM
02/11/09 02:07 PM
minnesota
Kirby Offline OP
Kirby  Offline OP
minnesota
I have the BS at home- I'll take a look
Re: Factory Defect? [Re: Kirby] #214921
02/11/09 02:12 PM
02/11/09 02:12 PM
cataclysm80 Offline
cataclysm80  Offline
Interesting...
Tav
Re: Factory Defect? [Re: TONY_DAGOSTINO] #214922
02/11/09 02:17 PM
02/11/09 02:17 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
I've seen a couple F8 cars that also had the blackout so I went ahead and did mine.
Interesting stuff.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Factory Defect? [Re: DPelletier] #214923
02/19/09 10:58 AM
02/19/09 10:58 AM
minnesota
Kirby Offline OP
Kirby  Offline OP
minnesota
I dug out the BS for this car. The Spare Code is 15, wheel color TX9, "road" 15. Does this help? I can read most other codes on the sheet. Let me know if I should post any more info off it, such as build date?
Re: Factory Defect? [Re: Kirby] #214924
02/20/09 03:56 PM
02/20/09 03:56 PM
minnesota
Kirby Offline OP
Kirby  Offline OP
minnesota
