B1 MC heads for a 500" RB
#2147713
09/05/16 12:54 AM
09/05/16 12:54 AM
Posts: 248 near St Petersburg, FL
Lifsgrt
I need some help determining if I can run B1 MC heads on a factory 440 block with a 4.375 or less bore (currently 4.350). Other than shrouding, any issues with interference with the 2.4 Int valves? Thanks
B3 1969 Charger R/T SE, 440/727 with 3:91s running 11.07@120
Re: B1 MC heads for a 500" RB
[Re: WO23Coronet]
#2147750
09/05/16 01:36 AM
09/05/16 01:36 AM
Lifsgrt
Stock block required for the class. I plan billet aluminum caps and a girdle to shore up the bottom end, wanting to get 900 or so out of it. Just need to know if the 2.4" intake valves will work in a 4.350 bore AND if they'll be worse than smaller valves for a 500" bullet. I am buying used heads if they'll work, thanks.
[Re: Lifsgrt]
#2147816
09/05/16 05:47 AM
09/05/16 05:47 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Should clear fine...........if it won't, notch the bore. Not the first time that's had to be done. And with the right cam, you WON'T have to spin it to the moon to make it run.
As for stock block rule.........tell em its a 383 car.......LOL!!!
[Re: Monte_Smith]
#2147878
09/05/16 11:21 AM
09/05/16 11:21 AM
Lifsgrt
I can use any factory block size that was available in the car. It doesn't have to be the correct year, but I can't use a 400 or 360 block for instance in a 1969 car. Thanks for the replies.
[Re: Monte_Smith]
#2147884
09/05/16 11:29 AM
09/05/16 11:29 AM
Posts: 4,693 Wichita
GY3
Wichita
As for stock block rule.........tell em its a 383 car.......LOL!!! A grinder and JB weld makes "383" numbers on the side of the block rather easily if anyone gets nosy..
[Re: Lifsgrt]
#2147954
09/05/16 01:23 PM
09/05/16 01:23 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Consider a center weighted crank. It greatly reduces the stress shifted to the inner bearings because the counter weights are more in line with the forces they are offsetting. I saw the cap walk go away in a Megablock I have when I went to a center weighted crank, and the bob weight is 2432, pretty heavy. The cost difference is around 2500 for a crower, been a long time since I bought mine so it may be higher, but worth every dime for a project like yours. If you can use a 400 block, and lighten the rotating assembly as much as possible, the deal might live a decent life.
[Re: Lifsgrt]
#2148236
09/05/16 08:17 PM
09/05/16 08:17 PM
Posts: 4,255 Canada
WO23Coronet
Canada
Have you considered doing Darton sleeves? I know in a normal build it doesn't make sense but for a stock block class that you're obviously set on kill for it might make sense. Btw, there have been legit reports of 383's using 400 castings when the crossover was happening........I think for warranty blocks they used 400 castings. A 400 with Darton sleeves would get it done
[Re: camastomcat]
#2148470
09/06/16 12:48 AM
09/06/16 12:48 AM
Posts: 43,249 Bend,OR USA
Cab_Burge
That sure is pretty Polished and lightweight, maybe not a ultra lightweight, but lighter than ones I've weighed Tom, how long is the stroke on this one?
