O2 sensor placement?
#2147127
09/04/16 02:05 AM
09/04/16 02:05 AM
Posts: 20,192 Park Forest, IL
slantzilla
Park Forest, IL
Is it better to weld the bungs right into the headers or will I get better readings putting them in my collector extensions? My extensions will be 3"X24" long for now. Thanks!
Re: O2 sensor placement?
[Re: slantzilla]
#2147131
09/04/16 02:22 AM
09/04/16 02:22 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Put it about 6" behind the end of the primaries and make sure its pointed downward so it doesnt hold any water(above 9 oclock- 3 oclock).. dont get to close to the end of the collectors so it doesnt see the fresh air
[Re: slantzilla]
#2147152
09/04/16 04:24 AM
09/04/16 04:24 AM
Thumperdart
State of confusion
Agree, mines 6-7" past the merge just after the flange in my side pipes........
[Re: slantzilla]
#2147185
09/04/16 09:51 AM
09/04/16 09:51 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I read something that wanted them at least 18" from the end of the extension.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: slantzilla]
#2147238
09/04/16 12:14 PM
09/04/16 12:14 PM
slantzilla
Park Forest, IL
Yes, from what I've read too close to the outlet will cause lean readings. I want to do the best I can to not send myself in wrong directions to start.
[Re: slantzilla]
#2147240
09/04/16 12:22 PM
09/04/16 12:22 PM
MR_P_BODY
Yes, from what I've read too close to the outlet will cause lean readings. I want to do the best I can to not send myself in wrong directions to start. You said you would be adding collector extensions.. so you will be fine with what I said
[Re: slantzilla]
#2147250
09/04/16 12:35 PM
09/04/16 12:35 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
A very simple test to see if your particular combo is likely to pull "free air" back to the wideband, is to let it idle, and put a piece of paper at the exhaust exit. Seems crazy, but it is not uncommon for the paper to be pulled back against the pipe between pulses. If it does that, you need to move the sensor as far away from the exit as possible, or ignore the readings at low engine speeds. If it does do this, be sure to get a good seal at the header to extension connection.
[Re: slantzilla]
#2147406
09/04/16 04:55 PM
09/04/16 04:55 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
An O2 manufacturer, cant remember which one, said rule of thumb is 36" from closest exhaust port.
Mopar to the bone!!!
[Re: slantzilla]
#2147426
09/04/16 05:35 PM
09/04/16 05:35 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
And make sure you can get the damn thing screwed in after everything is installed. FYI...It's of major important you don't have any exhaust leaks prior to the O2 sensor.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: slantzilla]
#2147786
09/05/16 03:00 AM
09/05/16 03:00 AM
slantzilla
Park Forest, IL
Looks like 6" back from the primaries puts them about 4" from the exit flange. I can point them straight out to the sides and be able to get them in and out. Thanks everyone.
