O2 sensor placement? #2147127
09/04/16 02:05 AM
09/04/16 02:05 AM
Park Forest, IL
slantzilla Online content OP
slantzilla  Online Content OP
Park Forest, IL
Is it better to weld the bungs right into the headers or will I get better readings putting them in my collector extensions? My extensions will be 3"X24" long for now.
Thanks! wave
Re: O2 sensor placement? [Re: slantzilla] #2147131
09/04/16 02:22 AM
09/04/16 02:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Put it about 6" behind the end of the primaries
and make sure its pointed downward so it doesnt
hold any water(above 9 oclock- 3 oclock).. dont
get to close to the end of the collectors so it
doesnt see the fresh air
wave
Re: O2 sensor placement? [Re: MR_P_BODY] #2147134
09/04/16 02:34 AM
09/04/16 02:34 AM
Park Forest, IL
Park Forest, IL
Thanks Mike.
Re: O2 sensor placement? [Re: slantzilla] #2147152
09/04/16 04:24 AM
09/04/16 04:24 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Agree, mines 6-7" past the merge just after the flange in my side pipes........
Re: O2 sensor placement? [Re: slantzilla] #2147185
09/04/16 09:51 AM
09/04/16 09:51 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I read something that wanted them at least 18" from the end of the extension.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: O2 sensor placement? [Re: slantzilla] #2147238
09/04/16 12:14 PM
09/04/16 12:14 PM
Park Forest, IL
Park Forest, IL
Yes, from what I've read too close to the outlet will cause lean readings. I want to do the best I can to not send myself in wrong directions to start.
Re: O2 sensor placement? [Re: slantzilla] #2147240
09/04/16 12:22 PM
09/04/16 12:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You said you would be adding collector extensions.. so
you will be fine with what I said
wave
Re: O2 sensor placement? [Re: slantzilla] #2147246
09/04/16 12:28 PM
09/04/16 12:28 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Would the optimum location be different for a full exhaust system, rather than open headers?
Re: O2 sensor placement? [Re: slantzilla] #2147250
09/04/16 12:35 PM
09/04/16 12:35 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
A very simple test to see if your particular combo is likely to pull "free air" back to the wideband, is to let it idle, and put a piece of paper at the exhaust exit.
Seems crazy, but it is not uncommon for the paper to be pulled back against the pipe between pulses. If it does that, you need to move the sensor as far away from the exit as possible, or ignore the readings at low engine speeds.
If it does do this, be sure to get a good seal at the header to extension connection.
Re: O2 sensor placement? [Re: slantzilla] #2147406
09/04/16 04:55 PM
09/04/16 04:55 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
An O2 manufacturer, cant remember which one, said rule of thumb is 36" from closest exhaust port.
Mopar to the bone!!!
Re: O2 sensor placement? [Re: slantzilla] #2147426
09/04/16 05:35 PM
09/04/16 05:35 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
And make sure you can get the damn thing screwed in after everything is installed. whistling
FYI...It's of major important you don't have any exhaust leaks prior to the O2 sensor.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: O2 sensor placement? [Re: slantzilla] #2147786
09/05/16 03:00 AM
09/05/16 03:00 AM
Park Forest, IL
Park Forest, IL
Looks like 6" back from the primaries puts them about 4" from the exit flange. I can point them straight out to the sides and be able to get them in and out.
Thanks everyone. wave
