Page 1 of 3 1 2 3
Green bearings ÉÉ #2146102
09/02/16 01:12 PM
09/02/16 01:12 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
What`s the issue with green bearings - are these ball bearings as opposed to conical roller bearings?
Are roller anxle bearings no longer available? Seems to me that appropriate conical rollers would still be available from bearing supply places.
Re: Green bearings ÉÉ [Re: Stanton] #2146108
09/02/16 01:15 PM
09/02/16 01:15 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The original set 7 rear wheel bearings are alive and well. Use them whenever possible. Mopar provided us with the beast bearing as original equipment.
Folks think the green bearings are better because hey need no adjusting when intstalling axle shafts. As in no thinking required. It does make the math on narrowing a rear end easier.
Re: Green bearings ÉÉ [Re: NANKET] #2146122
09/02/16 01:32 PM
09/02/16 01:32 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree
Let the panic fan begin no
Re: Green bearings ÉÉ [Re: TJP] #2146125
09/02/16 01:40 PM
09/02/16 01:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
iagree
iagree
Re: Green bearings ÉÉ [Re: Stanton] #2146153
09/02/16 02:10 PM
09/02/16 02:10 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
i think if you are spinning your tires or cornering fast you will never see the benefit of tapered bearings---you cant get enough traction----if it did make a difference there would be ford and chevy axles litering the streets---now if you dropped your car off a cliff that bearing would get its full use but everything else will be bent-----and why did chrysler ditch them?
Re: Green bearings ÉÉ [Re: Stanton] #2146174
09/02/16 02:42 PM
09/02/16 02:42 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Eliminated because they are Expensive and take more time on the assembly line. Just like factories going to 4 lug wheels, you doing that also?
If you keep the tapered rear bearings cleaned and packed, have you ever had one fail?
It is not absolutely necessary, but if you want a cheap junk bearing, buy a 60's GM car with the axle as the bearing race.
Re: Green bearings ÉÉ [Re: NANKET] #2146178
09/02/16 02:52 PM
09/02/16 02:52 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I used the green bearings when I built the Dana 60 for the '64 Polara, but I won't use them again if I have a choice.
The Ramcharger has a Dana 60 that I built with large Ford ends and the large Ford sealed bearings. I don't have to play with axle bearing pre-load adjustment or worry that I have not packed enough grease in the wheel bearings. That is old school.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Green bearings ÉÉ [Re: Stanton] #2146180
09/02/16 03:04 PM
09/02/16 03:04 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Green bearing are for lazy mechanics. Now if you want US made tapered roller bearing you have to go to a industrial supply house.
Re: Green bearings ÉÉ [Re: NANKET] #2146238
09/02/16 04:27 PM
09/02/16 04:27 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Never had a Green Bearing failure or issue in 3 decades of use in Dana 60's or 8 3/4 rears on the street or track/road course, I have had several failures of factory tapered bearings in the last 40 years however...go "green" IMHO
Re: Green bearings ÉÉ [Re: NANKET] #2146315
09/02/16 06:45 PM
09/02/16 06:45 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
On the other hand GM's half- a-- penny piching design has resulted in a money making opportunity for the axle Mfr's
whistling
Re: Green bearings ÉÉ [Re: DAYCLONA] #2146320
09/02/16 06:51 PM
09/02/16 06:51 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
My experiences are quite the opposite in that I have seen several green bearing failures anywhere from 10K- 50K miles but know of several factory cars that have exceeded 250K with no rear end service of any kind. I would question how many of the "green bearing" conversion vehicles have seen that kind of service. whistling shruggy
Re: Green bearings ÉÉ [Re: Stanton] #2146438
09/02/16 10:23 PM
09/02/16 10:23 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Been using Green bearings for many years without a single issue....same goes for factory tapered bearings. What's bad for axle bearings are rear wheels with excessive offset. Seen quite a few with so much offset they were literally riding on the inside half of the tire.
Re: Green bearings ÉÉ [Re: Stanton] #2146592
09/03/16 02:10 AM
09/03/16 02:10 AM
Tacoma, Washington USA
Adam71Charger Offline
I have green bearings installed on my dana 60. I have to admit, they made me nervous when I saw that there really isn't much keeping them in place, specifically on fast hard turns. But I've never heard of them failing or sliding out of place so if they work/last just as good as properly set tapered bearings I see no reason not to use them
Re: Green bearings ÉÉ [Re: Adam71Charger] #2146713
09/03/16 11:44 AM
09/03/16 11:44 AM
central il.
second 70 Offline
second 70  Offline
central il.
It depends on what green bearings you buy. I replaced an old set in my Dana where the plate was made on the bearing and were bent. I replaced them with a bearing with a separate plate that Dr. Diff recommends and sells what a difference in quality and strength. Trust Cass you get what you pay for.
Re: Green bearings ÉÉ [Re: Stanton] #2146731
09/03/16 12:24 PM
09/03/16 12:24 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
in my opinion the only way to properly clean and pack the tapered bearings is to cut them off and put on new ones----yeah i know there are guys that say they can pack them by sqeasing grease in around the corner and turning them----but you sure dont do your front hubs that way do you?-----maybe there is a way to put a grease zerk on the hub and do them like a trailer axle--then you would be in danger of taking out the seal with too much grease------not much in favor with the make do idea.....
Re: Green bearings ÉÉ [Re: savoy64] #2146766
09/03/16 01:34 PM
09/03/16 01:34 PM
I the first set of "green" bearings I bought from Summers Bros. back in the mid 1970s failed and allowed the axle to slide out of the rear end housing on street car due to the inner retainer sliding out of place shock The customer was on his way to northern CA from So Ca and had to have it fixed on the road, NOT GOOD work Same thing on a drag car at the races, retainer didn't hold the bearing in place and the axle slid out making the tires rub on the rear 1/4 panels puke
Maybe Murphy loved messing with me back then, whistling
No other failures since then shruggy
The tapered Timken Roller bearings are a lot sronger for road use as well as being a lot more money when replacing them shruggy
I use to work in service stations as a kid and I have replaced a lot more ball bearings and races on the front hubs of the older GM cars than on either Ford or Mopars with tapered ball bearings back then work shruggy
The ball bearings will not take any side preload at all, if you run them to loose or to tight on the preload they will fail shruggy
Not so on the Timken tapered roller bearings scope
Re: Green bearings ÉÉ [Re: Stanton] #2146774
09/03/16 01:43 PM
09/03/16 01:43 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Stanton--what are the "EE"s with the funky solo umlauts doing in the title of your post???
Re: Green bearings ÉÉ [Re: Pacnorthcuda] #2147187
09/04/16 09:57 AM
09/04/16 09:57 AM
moparx Offline
moparx  Offline
i didn't think anyone knew what umlauts were any more ! are you old [like me] and did you [kinda] pay attention in english class ? biggrin
beer
Re: Green bearings ÉÉ [Re: Stanton] #2147210
09/04/16 11:08 AM
09/04/16 11:08 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Keys are small ... thumbs are big. Hitting two keys at once changes some of the characters on an bilingual keyboard. Didn't notice till the next day.
Re: Green bearings ÉÉ [Re: Stanton] #2147330
09/04/16 02:51 PM
09/04/16 02:51 PM
I first thought that was Canadien for EHH EHH grin
Page 1 of 3 1 2 3
