Re: Green bearings ÉÉ
[Re: NANKET]
#2146178
09/02/16 02:52 PM
09/02/16 02:52 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I used the green bearings when I built the Dana 60 for the '64 Polara, but I won't use them again if I have a choice.
The Ramcharger has a Dana 60 that I built with large Ford ends and the large Ford sealed bearings. I don't have to play with axle bearing pre-load adjustment or worry that I have not packed enough grease in the wheel bearings. That is old school.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: NANKET]
#2146238
09/02/16 04:27 PM
09/02/16 04:27 PM
Posts: 18,157 Mass
DAYCLONA
Mass
If you keep the tapered rear bearings cleaned and packed, have you ever had one fail?
Never had a Green Bearing failure or issue in 3 decades of use in Dana 60's or 8 3/4 rears on the street or track/road course, I have had several failures of factory tapered bearings in the last 40 years however...go "green" IMHO
[Re: savoy64]
#2146766
09/03/16 01:34 PM
09/03/16 01:34 PM
Posts: 43,173 Bend,OR USA
Cab_Burge
I the first set of "green" bearings I bought from Summers Bros. back in the mid 1970s failed and allowed the axle to slide out of the rear end housing on street car due to the inner retainer sliding out of place The customer was on his way to northern CA from So Ca and had to have it fixed on the road, NOT GOOD Same thing on a drag car at the races, retainer didn't hold the bearing in place and the axle slid out making the tires rub on the rear 1/4 panels Maybe Murphy loved messing with me back then, No other failures since then The tapered Timken Roller bearings are a lot sronger for road use as well as being a lot more money when replacing them I use to work in service stations as a kid and I have replaced a lot more ball bearings and races on the front hubs of the older GM cars than on either Ford or Mopars with tapered ball bearings back then The ball bearings will not take any side preload at all, if you run them to loose or to tight on the preload they will fail Not so on the Timken tapered roller bearings
[Re: Stanton]
#2147210
09/04/16 11:08 AM
09/04/16 11:08 AM
Posts: 8,872 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Stanton--what are the "EE"s with the funky solo umlauts doing in the title of your post??? Keys are small ... thumbs are big. Hitting two keys at once changes some of the characters on an bilingual keyboard. Didn't notice till the next day.
