Re: Hemi camshaft
[Re: 71birdJ68]
#2144976
08/31/16 10:47 PM
08/31/16 10:47 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Mopar Rich on here, part of what you are looking for is in his book too. I called Chase Knight at Crane Cams but someone said he retired but Crane spec'd out a cam very similar to whats in Rich's book. Also consider Bullet cams. One other thing to consider is what rockers you are using, My oem wide pads were so bad on the ratio that I was losing about .100 on valve lift with a .628 cam. Good luck, Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
Re: Hemi camshaft
[Re: Tech Instructor]
#2145220
09/01/16 10:19 AM
09/01/16 10:19 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Dwayne Porter (802) 951-1955 Porter Racing Heads. You will not go wrong w/ Dwayne! He's spec'd the cams in all my stuff and I'm very happy w/ them.
Re: Hemi camshaft
[Re: 73DAD]
#2145258
09/01/16 11:29 AM
09/01/16 11:29 AM
Posts: 4,454 Morristown Tn.
71birdJ68
Morristown Tn.
With alum block, heads, intake it should weigh around what a 360 weighs. Also alum bell housing and drive shaft. BUT, don't envious, I bought this engine from David Everhart, and after just 2000 miles I am having to put new liners in it and rings and bearings, The dist drive was messed up and had to be fixed. It will be thousands of dollars to fix. The cam is a chive grind and I'm thinking about something better.
Re: Hemi camshaft
[Re: 71birdJ68]
#2145294
09/01/16 12:14 PM
09/01/16 12:14 PM
an8sec70cuda
My all aluminum hemi weighs the same as the iron block/aluminum headed 440 it replaced.
