Hemi camshaft #2144925
08/31/16 10:05 PM
08/31/16 10:05 PM
Morristown Tn.
71birdJ68 Offline OP
Morristown Tn.
I need to make a cam selection for a 528 Hemi, who would be the best person to talk to for that? And how could I contact them?
Re: Hemi camshaft [Re: 71birdJ68] #2144936
08/31/16 10:15 PM
08/31/16 10:15 PM
New England
Tech Instructor Offline
New England
Dwayne Porter (802) 951-1955 Porter Racing Heads.
Re: Hemi camshaft [Re: 71birdJ68] #2144976
08/31/16 10:47 PM
08/31/16 10:47 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Mopar Rich on here, part of what you are looking for is in his book too. I called Chase Knight at Crane Cams but someone said he retired but Crane spec'd out a cam very similar to whats in Rich's book. Also consider Bullet cams. One other thing to consider is what rockers you are using, My oem wide pads were so bad on the ratio that I was losing about .100 on valve lift with a .628 cam. Good luck, Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Hemi camshaft [Re: astjp2] #2145023
08/31/16 11:22 PM
08/31/16 11:22 PM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
How about Racer Brown?
Re: Hemi camshaft [Re: Tech Instructor] #2145177
09/01/16 04:09 AM
09/01/16 04:09 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
iagree
Re: Hemi camshaft [Re: 71birdJ68] #2145198
09/01/16 09:35 AM
09/01/16 09:35 AM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
What is your combo if you don't mind me asking? What are you putting it in?
Re: Hemi camshaft [Re: 73DAD] #2145206
09/01/16 09:57 AM
09/01/16 09:57 AM
Morristown Tn.
Morristown Tn.
It is a 71 RR with 3:54 gears and G-60/15 tires. Stock repo intake with 650 thunder series carbs and TTI headers. The trans is a Passon 4 speed OD. Stage V heads with some sort of port work, I just don't know who did them. Aluminum block. Street driven car.
Re: Hemi camshaft [Re: Tech Instructor] #2145220
09/01/16 10:19 AM
09/01/16 10:19 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
iagree You will not go wrong w/ Dwayne! He's spec'd the cams in all my stuff and I'm very happy w/ them.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Hemi camshaft [Re: 71birdJ68] #2145221
09/01/16 10:20 AM
09/01/16 10:20 AM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
That sounds bad-a--! I'm envious of your aluminum stuff. Just finished a 528 hemi in my car but went all iron, stock appearing route and its friggin heavy!
Re: Hemi camshaft [Re: 71birdJ68] #2145242
09/01/16 10:58 AM
09/01/16 10:58 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Ray Barton spec'd the flat solid cam for my 540.
https://www.facebook.com/SRTeric/videos/1239616772751002/
Master, again and still
Re: Hemi camshaft [Re: 73DAD] #2145258
09/01/16 11:29 AM
09/01/16 11:29 AM
Morristown Tn.
Morristown Tn.
With alum block, heads, intake it should weigh around what a 360 weighs. Also alum bell housing and drive shaft. BUT, don't envious, I bought this engine from David Everhart, and after just 2000 miles I am having to put new liners in it and rings and bearings, The dist drive was messed up and had to be fixed. It will be thousands of dollars to fix. The cam is a chive grind and I'm thinking about something better.
Re: Hemi camshaft [Re: 71birdJ68] #2145294
09/01/16 12:14 PM
09/01/16 12:14 PM
My all aluminum hemi weighs the same as the iron block/aluminum headed 440 it replaced.
CHIP
