Proper primer for painting engine #214255
02/04/09 07:19 PM
02/04/09 07:19 PM
wisconsin
swifter Offline OP
swifter  Offline OP
wisconsin
Is epoxy primer made in spray cans???? or do you use self-etching primer--Cast iron block with alum.heads and alum timing cover thanks
2007 Ram 2500 Cummins 2008 Dodge Nitro 1970 340 Valiant Duster
Re: Proper primer for painting engine [Re: swifter] #214256
02/04/09 07:43 PM
02/04/09 07:43 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I spray it all down with Brake Parts Cleaner and then just spray on the color.
Re: Proper primer for painting engine [Re: 69Cuda340S] #214257
02/04/09 08:49 PM
02/04/09 08:49 PM
IN
ahy Offline
ahy  Offline
IN
I've used the Eastwood self etch with good results. I think the primer helps the paint stick better to the aluminum parts and gives better appearance on the iron.
Two part epoxy (cans only) would be better but not necessary for a decent paint job.
Re: Proper primer for painting engine [Re: 69Cuda340S] #214258
02/04/09 08:49 PM
02/04/09 08:49 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
me 2
Re: Proper primer for painting engine [Re: 69Cuda340S] #214259
02/04/09 08:57 PM
02/04/09 08:57 PM
Kirkland, Washington
Pacnorthcuda Offline
x 3.... you don't need primer on an engine
Re: Proper primer for painting engine [Re: swifter] #214260
02/04/09 09:18 PM
02/04/09 09:18 PM
Rome, Ga
sbhpcb Offline
sbhpcb  Offline
Rome, Ga
I sprayed a coat of epoxy primer then sprayed acrylic enamel with the touch up gun that came in my $100 3 pack special. I have about 700 miles on the motor and it looks great. This paint covered very very good. I really believe it is cheaper than spray cans IF you have the primer ect any way for your car.
Re: Proper primer for painting engine [Re: sbhpcb] #214261
02/04/09 09:26 PM
02/04/09 09:26 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
i put a thin dusting of ppg dp90 on my 400 sbc just because I had it lying around. So long as the block is clean (cleanliness is the key to the paint sticking) then you can just apply paint right over the bare metal.
Re: Proper primer for painting engine [Re: swifter] #214262
02/04/09 10:41 PM
02/04/09 10:41 PM
crlush Offline
crlush  Offline
I clean engine with wax and greese remover, then light coat of ppg dp epoxy sealer, then paint with ppg single stage with hardner, my engines been together 4 yrs now and it still looks like the paint is wet. great durability and if you chip paint from working on it you just get out the touchup brush and it looks like new again, cost more than can paint but I think you get better durability and looks better too.
Re: Proper primer for painting engine [Re: Pacnorthcuda] #214263
02/05/09 10:49 AM
02/05/09 10:49 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
primer is just more insulation to let your motor heat up more. and who wants that. primer isnt needed
