Turn Signal Lever for 1972 Plymouth Fury #2141196
08/26/16 10:46 AM
08/26/16 10:46 AM
Chicago area
drh4683 Offline OP
drh4683  Offline OP
Chicago area
I'm in need of a new turn signal lever with auto speed control for my '72 Fury (non-tilt column). The original lever was damaged before I got the car, something broke internally on the end by the speed control switch and it's very loose and sloppy and the resume return spring is also distorted. (Just to clarify, it's the lever assembly that's at fault, not the turn signal switch!) According to the '72 parts book, the lever assy. is part# 3488538 and was only used in 1972 and 1973, and fit all C-bodies and Imperial without tilt. It did not apply to any other body platform according to the manual. The last photo shows the wire harness associated with the speed control portion of the lever. I already did the usual ebay and google searches and came up with nothing (so far). I contacted the guys at "MoparCity" in Oregon, IL and they didn't have anything in their yard that matched. If anyone has a source or can help out, it would be much appreciated.
14047355_10207682428759062_3876610186689481616_o by drh4683, on Flickr
14115577_10207682428559057_214948505365452169_o by drh4683, on Flickr
14066494_10207682428359052_8344901459992218034_o by drh4683, on Flickr
Re: Turn Signal Lever for 1972 Plymouth Fury [Re: drh4683] #2141240
08/26/16 12:16 PM
08/26/16 12:16 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
My Grandfather had a '72 Fury Grand Coupe, same thing happened to it. They left it at our house circa 1975 while they were on vacation with my parents, I went to the junkyard and found a match for it and fixed while they were gone.
Find one on eBay that looks like it and has the tab for a screw to pass through into the switch and buy it. With the exception of tilt columns they're pretty much all the same, same attachment, same wiring connector. Mebbe E bodies are different, don't know, never stumbled across one. If it is for an E body they'll probably mention it and it'll be pricy. 2ยข
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Turn Signal Lever for 1972 Plymouth Fury [Re: drh4683] #2141267
08/26/16 01:24 PM
08/26/16 01:24 PM
Laveen, Arizona
GTSDart340 Offline
GTSDart340  Offline
Laveen, Arizona
Looks pretty similar to the one on my 72 D200. Try looking for a truck application.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: Turn Signal Lever for 1972 Plymouth Fury [Re: drh4683] #2141269
08/26/16 01:37 PM
08/26/16 01:37 PM
md
mopars4ever Offline
mopars4ever  Offline
md
supposed to be the same as these TURN SIG LEVER, KNOB & WIRING W/ SPD CONT, W/O TILT (SA 2947500, 2947954, 3488538, 3746518 P 71, 72-73 FURIES, 74-75; D 71, 72-73 POL, MON, 74 COR, 75; VAL, DART 75; CHGR 71, 74, 75 SE; C, IMP 70-75; 76 EX COMPACT; 77-78 Deception Pass Motor parts is suppose to have a NOS one at $160
Re: Turn Signal Lever for 1972 Plymouth Fury [Re: drh4683] #2141272
08/26/16 01:42 PM
08/26/16 01:42 PM
md
mopars4ever Offline
mopars4ever  Offline
md
http://www.ebay.com/itm/NOS-MOPAR-3746518-TURN-SIGNAL-SWITCH-W-CRUISE-1975-DART-VALIANT-71-73-FURY-/262400482521?hash=item3d18499cd9:g:ipAAAOSwXj5XGl4J&vxp=mtr
