I'm in need of a new turn signal lever with auto speed control for my '72 Fury (non-tilt column). The original lever was damaged before I got the car, something broke internally on the end by the speed control switch and it's very loose and sloppy and the resume return spring is also distorted. (Just to clarify, it's the lever assembly that's at fault, not the turn signal switch!) According to the '72 parts book, the lever assy. is part# 3488538 and was only used in 1972 and 1973, and fit all C-bodies and Imperial without tilt. It did not apply to any other body platform according to the manual. The last photo shows the wire harness associated with the speed control portion of the lever. I already did the usual ebay and google searches and came up with nothing (so far). I contacted the guys at "MoparCity" in Oregon, IL and they didn't have anything in their yard that matched. If anyone has a source or can help out, it would be much appreciated.
14047355_10207682428759062_3876610186689481616_o by
drh4683, on Flickr
14115577_10207682428559057_214948505365452169_o by
drh4683, on Flickr
14066494_10207682428359052_8344901459992218034_o by
drh4683, on Flickr
