Page 1 of 3 1 2 3
This 572 Predator engine Boatracer 572 built, is rocking #2139308
08/23/16 02:36 PM
08/23/16 02:36 PM
Salt Lake City
camastomcat Offline OP
Salt Lake City
These Predator engines are a different breed for sure. I finally have a feel for converter, gear, tune up, and potential performance. It's been running really good even in 8600 ft corrected air. Last weekend in 8200 ft corrected elevation, it ran between 7.59-7.61 all day.
Re: This 572 Predator engine Boatracer 572 built, is rocking [Re: camastomcat] #2139418
08/23/16 05:40 PM
08/23/16 05:40 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
That's fast! Is that about a 4.70 in the 1/8 ?
Re: This 572 Predator engine Boatracer 572 built, is rocking [Re: camastomcat] #2139442
08/23/16 06:06 PM
08/23/16 06:06 PM
Salt Lake City
Salt Lake City
No, really low 4.80's. It has more in it when the weather is better and the barometer goes up a bit. It was 25.56 last weekend. It's also a pretty mild Predator deal. Less than .900 lift and 15-1 compression.
Re: This 572 Predator engine Boatracer 572 built, is rocking [Re: camastomcat] #2139447
08/23/16 06:16 PM
08/23/16 06:16 PM
an8sec70cuda Offline
Glad to hear you're having a good time w/ it now! I know you've had some headaches lately w/ those Predator motors. Hope you keep getting faster!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: This 572 Predator engine Boatracer 572 built, is rocking [Re: camastomcat] #2139453
08/23/16 06:41 PM
08/23/16 06:41 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Still fast as heck at that altitude.
Re: This 572 Predator engine Boatracer 572 built, is rocking [Re: camastomcat] #2139464
08/23/16 07:05 PM
08/23/16 07:05 PM
Salt Lake City
Salt Lake City
I always knew they had the potential. The worst part is finding someone like Tony that had been running them successfully, as people like Indy were absolutely no help. And because Tony has been racing boats, it took me for ever to figure out the converter, gear, timing etc., that equates to the pavement. My 604 is ready now, and I will start next year with that. It made 1200HP, actually 1199.4.
Re: This 572 Predator engine Boatracer 572 built, is rocking [Re: camastomcat] #2140531
08/25/16 12:24 PM
08/25/16 12:24 PM
Salt Lake City
Salt Lake City
Thanks for the replies guys. I guess there isn't much interest in the Predator stuff here.
Re: This 572 Predator engine Boatracer 572 built, is rocking [Re: camastomcat] #2140534
08/25/16 12:29 PM
08/25/16 12:29 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I think their pretty sweet, just way out of my league.
Maybe it's hard to compare, but what are the major set up differences (gear, convertor etc) between a Predator and a similar 572 wedge you've had?
Re: This 572 Predator engine Boatracer 572 built, is rocking [Re: camastomcat] #2140538
08/25/16 12:46 PM
08/25/16 12:46 PM
Salt Lake City
Salt Lake City
Gear needs to be a tad more steep, at least with the 572, I don't know yet with the 604. So, from a 4.10 to a 4.30, I think it would help as they like higher RPM's. The timing is less, from 33-34 total, to 30-32 total. They like big carbs, 1250 and perhaps even bigger or 2. The converter should stall at least 6000, and 6200-6500 is even better.
The upside of these things are common intake/exhaust rockers, much higher flow, bigger cams are effective, they don't need as much compression but respond to more, and from what I hear they are very NOS friendly.
The downside is, don't try getting any info from Indy, they are more expensive than the B1 stuff, special headers, pistons, gaskets, etc.
Re: This 572 Predator engine Boatracer 572 built, is rocking [Re: camastomcat] #2140562
08/25/16 01:38 PM
08/25/16 01:38 PM
sing sing
U
unknown Offline
unknown  Offline
U
sing sing
Oh trust me, I have lots of interest in the Predator stuff and if and when the time comes to buy better heads then what i have it will be Predator heads. My junk has been sidelined for many years because of having a very busy job and having two kids to raise. I look at it like this, buy the Predator heads right from the start. If i only want to run in the 9s, mild porting and mild camshaft. The day i want to step it up, there's lots of room for improvement. By the way, good luck with yours.
Re: This 572 Predator engine Boatracer 572 built, is rocking [Re: camastomcat] #2140571
08/25/16 01:49 PM
08/25/16 01:49 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
would be fun to see that combo run in Bakersfield in the nice cool fall air that is coming! Glad it's running well and those are stout numbers up in the air. smile
Re: This 572 Predator engine Boatracer 572 built, is rocking [Re: J_BODY] #2140584
08/25/16 02:02 PM
08/25/16 02:02 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
First off congratulation on all the hard work and research on making these combos work. And you are right on the interest of MOST of our members. I follow these builds as I appreciate all the work and money involved in getting these combos to work even though at my age I will never own a set. Heck most of the guys kinda pass over even the B1 posts on here. You are even fighting a bigger up hill battle because you are racing a dragster. Most guys including myself are door car guys and when the dragsters come to the line we head to eat. Nothing personal but either you like them or you don't. I would quit racing if it came down to me having to own one even though they are " the best " bracket cars out there. I've seen guys that raced for 20 plus years and never win a race step into a dragster and go on a tear. Please keep up the good work and keep us in the loop.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: This 572 Predator engine Boatracer 572 built, is rocking [Re: pittsburghracer] #2140596
08/25/16 02:13 PM
08/25/16 02:13 PM
Salt Lake City
Salt Lake City
Yep, all good points on the dragster comments, and no arguments as to the appeal of watching them run. I will say, even though I have won more races with the dragster, it's not as easy as people think, but a definite advantage.
I have spent a lot on research and development for Indy and ultimately Mopar, but Boatracer572 has the most helpful with advice and help.
Glad to see some are interested.
Re: This 572 Predator engine Boatracer 572 built, is rocking [Re: pittsburghracer] #2140600
08/25/16 02:19 PM
08/25/16 02:19 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
My thoughts exactly!
I do like reading about the builds and combos.
Good luck ! beer
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: This 572 Predator engine Boatracer 572 built, is rocking [Re: camastomcat] #2140630
08/25/16 03:22 PM
08/25/16 03:22 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I have lots of interest in all the build posts too. Most of them are way out of my reach too.
I love reading them because it always amazes me how much I don't know.
Re: This 572 Predator engine Boatracer 572 built, is rocking [Re: slantzilla] #2140666
08/25/16 04:20 PM
08/25/16 04:20 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Glad you are finally having fun and past the point of spending lots of money. That's a great place to be!
Re: This 572 Predator engine Boatracer 572 built, is rocking [Re: camastomcat] #2140678
08/25/16 04:51 PM
08/25/16 04:51 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Post some pics of it sitting in the framerails. I like seeing that kind of stuff.
Re: This 572 Predator engine Boatracer 572 built, is rocking [Re: slantzilla] #2140679
08/25/16 04:52 PM
08/25/16 04:52 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Same here. Good to hear you've got a strong running combination with those heads. bow
Re: This 572 Predator engine Boatracer 572 built, is rocking [Re: camastomcat] #2140768
08/25/16 07:51 PM
08/25/16 07:51 PM
San Jose Ca.
boatracer572 Online content
boatracer572  Online Content
San Jose Ca.
Thanks Tom., would like to see you get that 6.9x time slip soon, like we talked about there is around 30 hp more to be had with a cam change.... how many runs on the springs in the 572 now....
Re: This 572 Predator engine Boatracer 572 built, is rocking [Re: camastomcat] #2140777
08/25/16 08:04 PM
08/25/16 08:04 PM
Salt Lake City
Salt Lake City
They have about 115 passes on them now. I just checked them all yesterday and they are all rock solid at 360 seat pressure. Valve adjustment doesn't move much either. Here's a pic in the trailer.
Page 1 of 3 1 2 3
