99 durango heater motor removal?? #214037
02/04/09 03:02 PM
02/04/09 03:02 PM
Coolville, Ohio
Lew Offline OP
Lew  Offline OP
Coolville, Ohio
anyone done this? how crazy is it to do? any tips? i have laid on my back and looked, but all im seeing is a mess. at low rpm i heard a bit of a rubbing sound, went to full thottle and ran fine, turned it off, wont fire back up, fuse is good, wassup??
Re: 99 durango heater motor removal?? [Re: Lew] #214038
02/04/09 03:30 PM
02/04/09 03:30 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you checked the fuses and heater motor resistor?
Re: 99 durango heater motor removal?? [Re: stumpy] #214039
02/04/09 03:48 PM
02/04/09 03:48 PM
Coolville, Ohio
Lew Offline OP
Lew  Offline OP
Coolville, Ohio
fuse is good, where is resister located?
Re: 99 durango heater motor removal?? [Re: Lew] #214040
02/04/09 04:19 PM
02/04/09 04:19 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
Passenger side, under dash. A bit cumbersome to do, but not hard.
Common problem. Stealership should stock them.
Common sense is a flower that does not grow in everybody's garden
Re: 99 durango heater motor removal?? [Re: Ron_M] #214041
02/04/09 04:44 PM
02/04/09 04:44 PM
Coolville, Ohio
Lew Offline OP
Lew  Offline OP
Coolville, Ohio
thanks, is there any way to test it when i get it out?
Re: 99 durango heater motor removal?? [Re: Lew] #214042
02/04/09 05:02 PM
02/04/09 05:02 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Sure, use an OHM meter and see if you have different resistances through the different levels if the resistance is open than you know you have a bad resistor.
Re: 99 durango heater motor removal?? [Re: Cuda340] #214043
02/04/09 05:27 PM
02/04/09 05:27 PM
Coolville, Ohio
Lew Offline OP
Lew  Offline OP
Coolville, Ohio
thanks,i was thinking in that direction, just thought i would see if i could get a conformation, thanks again, im headed to the garage now, to cold here for no heat.
Re: 99 durango heater motor removal?? [Re: Lew] #214044
02/05/09 07:51 AM
02/05/09 07:51 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
You for sure dont want to change the motor.The entire box has to come out.Its a real pain.Rocky
Chrysler Firepower
Re: 99 durango heater motor removal?? [Re: Lew] #214045
02/05/09 11:58 AM
02/05/09 11:58 AM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
I think that the dash has to come off in order to gain access to the blower motor. I know for fact this is true for the heater core and evaporator. If you do have to do this job, by yourself or having it done I suggest you do all of the above at the same time. The parts are cheap compared to the work involved. This is a big deal and expensive to have done. For more details go here http://www.dakota-durango.com/forum/index.php?
Ken
