How many quarts of trans fluid are required in a SB 727? #2139601
08/23/16 10:55 PM
08/23/16 10:55 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
If I have a bone dry transmission (i.e. no fluid in torque converter either), how many quarts of trans fluid do I need for a small block 727 trans with a stock pan?
Re: How many quarts of trans fluid is required in a SB 727? [Re: vinnyd76] #2139608
08/23/16 11:02 PM
08/23/16 11:02 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
According to the FSM, for 74, 360 with 727, 16pts for std convertor, high speed says it is 13.5
Re: How many quarts of trans fluid is required in a SB 727? [Re: vinnyd76] #2139703
08/24/16 01:31 AM
08/24/16 01:31 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
In the past I've bought 9 quarts and that was enough
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: How many quarts of trans fluid is required in a SB 727? [Re: HemiRick] #2139988
08/24/16 04:10 PM
08/24/16 04:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
iagree Unless you have an giant cooler.
Re: How many quarts of trans fluid is required in a SB 727? [Re: vinnyd76] #2140083
08/24/16 06:41 PM
08/24/16 06:41 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
When putting it together, should you pour some fluid in the empty converter before installing it on the trans?
Re: How many quarts of trans fluid is required in a SB 727? [Re: NANKET] #2140105
08/24/16 07:18 PM
08/24/16 07:18 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Yes.
I have mechanical Aptitude.
I can screw up anything.
Re: How many quarts of trans fluid are required in a SB 727? [Re: vinnyd76] #2140149
08/24/16 08:27 PM
08/24/16 08:27 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I always used 17 pints... shruggy
JB Rhinehart, Realist
A-Body's RULE!
