Rust remover product for slight surface rust ? #2136808
08/19/16 07:55 PM
08/19/16 07:55 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Well some of these freshly machined parts are not quite
so fresh anymore, my fault, there is now a bit of rust.
Anyone use a brush-on goo type rust remover ? How about
a submerged bath type ?
Re: Rust remover product for slight surface rust ? [Re: hemienvy] #2136920
08/19/16 10:56 PM
08/19/16 10:56 PM
I would try WD40 and a wire brush, several times until clean scope Once the major rust is gone try using ATF and then cleaning solvent to remove the ATF several times until it shines like new machining thumbs
If it is pitted bad enough that you can feel the pits with your finger nails your to late shruggy
Re: Rust remover product for slight surface rust ? [Re: Cab_Burge] #2136924
08/19/16 11:09 PM
08/19/16 11:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What was the old stuff... Naval Jelly.. wasnt that
rust remover.. all depends on what parts your talking
about on what can be done... WD40 and a scotchbrite
wave
Re: Rust remover product for slight surface rust ? [Re: hemienvy] #2136988
08/20/16 12:41 AM
08/20/16 12:41 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Depending on how big the parts are (block or something more manageable?) Evaporust works great and no worry about scratching or marring the surface like with wire brushes, etc.
(I use it on vintage tools, and works great and no worry about hurting the fine stamped in writing, etc on them.)
For example...(and these were only soaked and then rinsed off, nothing else) WWII issue wrench handle after a soak;
And a 1927 extension after a few hours soaking...
Re: Rust remover product for slight surface rust ? [Re: hemienvy] #2136995
08/20/16 12:47 AM
08/20/16 12:47 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Mix vinager, lemon juice and a little salt, use a sprayer, rust will be gone
Re: Rust remover product for slight surface rust ? [Re: hemienvy] #2137252
08/20/16 02:25 PM
08/20/16 02:25 PM
Wisconsin
Medlock51 Offline
Medlock51  Offline
Wisconsin
I have a drum of a 6-1 water/molasses mix sitting outside my shop... works great for derusting everything from wheels to heads to blocks and everything in between.
A 40lb bag of dry molasses (animal feed) is about $18.00.... I mix a fresh batch every spring. 40 bs. lasts me three years.
I use my shop crane to lift heavy parts in and out of the drum. When the cold weather comes I simply dump the old stuff out into my driveway and wash it into the street... it's all natural so the greenies can't say a thing.
Re: Rust remover product for slight surface rust ? [Re: cudaman1969] #2137282
08/20/16 03:08 PM
08/20/16 03:08 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The acid in the vinegar will eat the rust, what's the lemon juice and salt supposed to do?
Re: Rust remover product for slight surface rust ? [Re: DaytonaTurbo] #2137328
08/20/16 04:08 PM
08/20/16 04:08 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
The lemon juice is acid too, salt, from what I understand helps mix the batch. I also have a molasses tank, made in June, so far works real good. I didn't know the batch life, thanks for that info. So far I've done four doors, three fenders, a hood, grill surround and bunch of small pieces, roof goes in next, very happy with results.
Re: Rust remover product for slight surface rust ? [Re: hemienvy] #2137364
08/20/16 05:55 PM
08/20/16 05:55 PM
Wisconsin
Medlock51 Offline
Medlock51  Offline
Wisconsin
Here's my deal... the scum on top is a combo of rust and grease. The solution isn't a degreaser but it does loosen the grease and old paint.
These rocker arm shafts spent over 10 years outside on an engine without valve covers...
The springs are old stockers that will replace the broken one's in my dropped '97 Ram... the bracket is off my dirt late model quick change. Again it was very rusty after 20 years of storage.
The key to this solution is patience.... don't expect haevy rust to disappear in a day. Light 'shelf' rust will dissolve in a few days... heavy stuff may take weeks. just dip it and forget it.
Re: Rust remover product for slight surface rust ? [Re: Medlock51] #2137411
08/20/16 07:25 PM
08/20/16 07:25 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I also use long gloves, the stink takes awhile to come off your hands or clothes. You're right it takes weeks for the heavy rust. AND it doesn't harm the metal, its a biological process.
Re: Rust remover product for slight surface rust ? [Re: cudaman1969] #2139571
08/23/16 10:12 PM
08/23/16 10:12 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Hey guys, thanks very much, good points all around !
Now, let me throw this in the mix. It occurred to me that
sandblasting with walnut shells might work. Two of my rusted
parts are a block and a crank.
Would you walnut blast the crank journals or the cylinder bores
(was freshly crosshatched) ?
Re: Rust remover product for slight surface rust ? [Re: hemienvy] #2139958
08/24/16 03:28 PM
08/24/16 03:28 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
EvapoRust is amazing stuff. Will not touch the base metal, and rust is completely gone after a 24 hour soak. Not cheap, though. To do an engine block, you would need to buy at least 5 gallons, which would cost about $100.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Rust remover product for slight surface rust ? [Re: hemienvy] #2139981
08/24/16 04:05 PM
08/24/16 04:05 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
You can use vinegar. It's cheap, (about $3 or less per gallon) and bio friendly.
I used an old storage container, doing a resto job on an antique. about two days all rust was gone! The rinse with water and blow dry.
I dropped this old wheel (1968) in to see what it would do for it.
A little brushing will help.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Rust remover product for slight surface rust ? [Re: DusterDave] #2140042
08/24/16 05:27 PM
08/24/16 05:27 PM
Catskill Mountains, NY
Joe12459 Offline
Joe12459  Offline
I've had a lot of luck with EvapoRust. It's very safe and effective.
Re: Rust remover product for slight surface rust ? [Re: Joe12459] #2140059
08/24/16 05:55 PM
08/24/16 05:55 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
One product that no one has mentioned yet is Ospho. I don't know if I would spray it on machined surfaces like crank journals, but it does work fast at removing light surface rust. It's commonly used on automotive sheet metal.
Re: Rust remover product for slight surface rust ? [Re: hemienvy] #2142922
08/29/16 03:27 AM
08/29/16 03:27 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
evaporust. 20 bucks from wall mart or tractor supply..
stuff works excellent... all i ever use now and wont take paint off either.
washes off with water...
or use it in a spray bottle to protect bare metal.
works excellent and wont turn it black.
wallly world has the best price.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Rust remover product for slight surface rust ? [Re: hemienvy] #2147749
09/05/16 01:36 AM
09/05/16 01:36 AM
Wisconsin
Medlock51 Offline
Medlock51  Offline
Wisconsin
All good ideas..
