Header to oil pan clearance? #2139743
08/24/16 04:11 AM
08/24/16 04:11 AM
Park Forest, IL
slantzilla Offline OP
Park Forest, IL
I mocked up everything in my Duster Sunday and everything fit fine with one little glitch, 2 tubes of my driver's side header run into the kickout on the Milodon pan. I think it won't take much to make some clearance in the kickout, but how much is enough? 1/4-1/2"?
Thanks! wave
Re: Header to oil pan clearance? [Re: slantzilla] #2139788
08/24/16 10:18 AM
08/24/16 10:18 AM
an8sec70cuda Offline
I'd be happy with 1/4".
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Header to oil pan clearance? [Re: an8sec70cuda] #2139801
08/24/16 11:08 AM
08/24/16 11:08 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
On my 1970 small block duster with the 1 7/8 headers Matt and I BOTH had to modify our headers with a 4 pound hammer. Today and tomorrow I will be re-routing the 2 tubes so I can get my engine diaper on.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Header to oil pan clearance? [Re: pittsburghracer] #2139803
08/24/16 11:09 AM
08/24/16 11:09 AM
PA.
"Little"John
"Little"John
PA.
Our issue is on the passenger-side.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Header to oil pan clearance? [Re: slantzilla] #2139804
08/24/16 11:12 AM
08/24/16 11:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
When I build my headers I like to be able to slide
my hand past the tubes and the pan.. about 3/4"
wave
Re: Header to oil pan clearance? [Re: slantzilla] #2139811
08/24/16 11:22 AM
08/24/16 11:22 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have about 1/4-3/8" on my small block with coated headers.
Re: Header to oil pan clearance? [Re: justinp61] #2139838
08/24/16 12:06 PM
08/24/16 12:06 PM
PA.
"Little"John
"Little"John
PA.
Diaper rules are coming guys so if you are going to modify anything plan ahead. 10.50 at Keystone as of 7-1-16
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Header to oil pan clearance? [Re: slantzilla] #2139851
08/24/16 12:33 PM
08/24/16 12:33 PM
Park Forest, IL
Park Forest, IL
Thanks guys!
Mine are close enough to fitting I could probably get away with using a set of Percy's gaskets and it would space the header over enough to clear, but I think it will be fairly easy to massage the pan a little to be safe with any gasket. hammer
Re: Header to oil pan clearance? [Re: slantzilla] #2140719
08/25/16 06:16 PM
08/25/16 06:16 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
3/16 between my starter and headers
