Header to oil pan clearance?
#2139743
08/24/16 04:11 AM
08/24/16 04:11 AM
Posts: 20,190 Park Forest, IL
slantzilla
Park Forest, IL
I mocked up everything in my Duster Sunday and everything fit fine with one little glitch, 2 tubes of my driver's side header run into the kickout on the Milodon pan. I think it won't take much to make some clearance in the kickout, but how much is enough? 1/4-1/2"? Thanks!
Re: Header to oil pan clearance?
[Re: slantzilla]
#2139788
08/24/16 10:18 AM
08/24/16 10:18 AM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
[Re: an8sec70cuda]
#2139801
08/24/16 11:08 AM
08/24/16 11:08 AM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
On my 1970 small block duster with the 1 7/8 headers Matt and I BOTH had to modify our headers with a 4 pound hammer. Today and tomorrow I will be re-routing the 2 tubes so I can get my engine diaper on.
[Re: pittsburghracer]
#2139803
08/24/16 11:09 AM
08/24/16 11:09 AM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Our issue is on the passenger-side.
[Re: justinp61]
#2139838
08/24/16 12:06 PM
08/24/16 12:06 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Diaper rules are coming guys so if you are going to modify anything plan ahead. 10.50 at Keystone as of 7-1-16
[Re: slantzilla]
#2139851
08/24/16 12:33 PM
08/24/16 12:33 PM
slantzilla
Park Forest, IL
Thanks guys! Mine are close enough to fitting I could probably get away with using a set of Percy's gaskets and it would space the header over enough to clear, but I think it will be fairly easy to massage the pan a little to be safe with any gasket.
