need advice for where to place WB Oxygen sensor #213893
02/04/09 12:51 PM
02/04/09 12:51 PM
Cheswick, PA
Bob_Spelic Offline OP
Cheswick, PA
For a drag race only car, no exhaust just headers; where have you guys mounted the wide band Q2 sensor for an LM-1 kit?
Pictures would also be appreciated.
Bob spelic
Re: need advice for where to place WB Oxygen sensor [Re: Bob_Spelic] #213894
02/04/09 12:54 PM
02/04/09 12:54 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I would put it in the collector. If you don't have extensions at the ends of the collectors, I would mount it as far to the front of the collector as I could, I hear you don't want it too close to the outlet to prevent outside oxygen to contaminate the w/b's reading. I wouldn't put it in a primary tube though, because you never know if that one cylinder is indicitave of the actual a/f of the whole.
Re: need advice for where to place WB Oxygen sensor [Re: Bob_Spelic] #213895
02/04/09 12:59 PM
02/04/09 12:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Couple questions Bob, is it on the digger you show
and will you be leaving them in the pipes I dont like
leaving them in
Re: need advice for where to place WB Oxygen sensor [Re: MR_P_BODY] #213896
02/04/09 01:17 PM
02/04/09 01:17 PM
Sao Paulo, Brazil
dart_73_br Offline
dart_73_br  Offline
Sao Paulo, Brazil
I think that in Innovates user guide, they say thew correct distance to install the bungs. You canŽt place it to near from the heads because the high temperature. (see attach)
IŽll take a look.
Re: need advice for where to place WB Oxygen sensor [Re: dart_73_br] #213897
02/04/09 01:42 PM
02/04/09 01:42 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Bung goes in top where the tubes meet the collector and on the collector or to the side near the top.Disconnect E-vac if you have it for a run.
Re: need advice for where to place WB Oxygen sensor [Re: cudabunch] #213898
02/04/09 07:52 PM
02/04/09 07:52 PM
NC
440Jim Offline
440Jim  Offline
NC
FYI,
I have mine in a 4" dia collector, just after the tubes maybe 8" from the outlet. It gets all sorts of outside air at low throttle positions, so it is useless in the pits. When I footbrake it, it clears up nicely around 2000-2200 rpm and seems fine at WOT. I think a 12-18" extension would allow it to work at idle, etc.
Re: need advice for where to place WB Oxygen sensor [Re: 440Jim] #213899
02/05/09 01:20 AM
02/05/09 01:20 AM
USA
Ron Silva Offline
Ron Silva  Offline
USA
I always run mine in the collector.
SRT DEMON ONE SEAT
Re: need advice for where to place WB Oxygen sensor [Re: MR_P_BODY] #213900
02/05/09 09:27 AM
02/05/09 09:27 AM
Cheswick, PA
Cheswick, PA
Mr. P body, it will be in the dragster show. i will not leave them in I will remove the sensors after geting the tune up correct and put plugs in the bungs. I am trying E85 on the car and need to find the safe tune without hurting anything. The calculated compression is 13.7 so I do not really know if the e85 will work for me.
bob Spelic
Re: need advice for where to place WB Oxygen sensor [Re: Bob_Spelic] #213901
02/05/09 10:02 AM
02/05/09 10:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
bob Spelic
Bob try to keep the bungs as far forward as possible
but still in the path of all 4 tubes, like has been
said already if you get near the collector exit it
can pick up outside air. You could had a slip fit
collector extension with the bung on the front of
it(a collector that can tighten down) then when
completed you take it off.
I run 14.1:1 on E-85 but my cam has a 112 LSA installed
at 106 or 108 I forget right now... runs good on it
Re: need advice for where to place WB Oxygen sensor [Re: MR_P_BODY] #213902
02/05/09 10:36 AM
02/05/09 10:36 AM
Cheswick, PA
Cheswick, PA
I am 13.6 with the ross big dome piston (14cc), EZ-1 heads at 75 CC and a .060 cometic gasket (to get the static compression down). My cam is 282/274 @ .050 on a 110 CL in at 108. I am very worried about beig able to run E85 and bought the LM-1 as I think I need all the help I can get in getting it set up.
The removable collector extension sounds like a good idea.
Bob Spelic
Re: need advice for where to place WB Oxygen sensor [Re: Bob_Spelic] #213903
02/05/09 10:44 AM
02/05/09 10:44 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Bob Spelic
Bob I wouldnt worry with the 110 LSA, your 2* shorter
and a 1/2 compression point less. The E-85 will
run cooler so that less prone to detonation .
If you go with the collector extension make sure its
sealed so you dont pull in air at the joint and get
a false reading
Re: need advice for where to place WB Oxygen sensor [Re: cudabunch] #213904
02/05/09 01:32 PM
02/05/09 01:32 PM
NY
challenger451ci Offline
NY
Does E-VAC effect the O2 reading? Would it effect if the O2 sensor bung was upstream from the E-VAC????
Re: need advice for where to place WB Oxygen sensor [Re: challenger451ci] #213905
02/05/09 01:37 PM
02/05/09 01:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes the evac will effect the reading... unless its
up stream like you stated
Re: need advice for where to place WB Oxygen sensor [Re: Bob_Spelic] #213906
02/06/09 11:27 AM
02/06/09 11:27 AM
NC
440Jim Offline
440Jim  Offline
NC
My 511 CID has 13.5 CR, flat tops, 68cc, 0.039" quench. My cam is 279/287 at 0.050" on a 110 LC in at 106.
I ran E85 with 83-84% ethanol all last year in this setup with no problems. I would worry about winter/spring grade E85 (70-80 percent ethanol). I call the station and make sure the batch they have is a high percent ethanol, then fill a 55 gallon barrel.
Re: need advice for where to place WB Oxygen sensor [Re: Bob_Spelic] #213907
02/06/09 11:51 AM
02/06/09 11:51 AM
Cheswick, PA
Cheswick, PA
Thans for getting back to me. I will weld up the headers next week. So, the LM-1 will allow me to get the air/fuel ratio right, but is there any way of knowing if the engine is detonating (knocking)? I certainly can't hear it.
Do you guys just compare Race gas performance to E85 perfomance and if they are about the same and the A/F ratio is in the rich side, assume that the engine is OK with the Octane of the fuel.
Sorry to be an idiot here, but I ahve the same concerns with Race gas and add Tetraethelene Lead to it to be on the safe side.
How do you tell if the engine has enough octane?
Bob Spelic
Re: need advice for where to place WB Oxygen sensor [Re: Bob_Spelic] #213908
02/06/09 12:40 PM
02/06/09 12:40 PM
PA
ajcasini Offline
ajcasini  Offline
PA
I have a question on this as well...Make sure you answers Bobs first.
What needs to be done to the carb to make it E85 compatible? Can you just jet up a gas carb?
AJ
Re: need advice for where to place WB Oxygen sensor [Re: ajcasini] #213909
02/06/09 01:30 PM
02/06/09 01:30 PM
Cheswick, PA
Cheswick, PA
AJ, I will be sending you an email on the conversion.
bob
Re: need advice for where to place WB Oxygen sensor [Re: ajcasini] #213910
02/07/09 10:47 AM
02/07/09 10:47 AM
NC
440Jim Offline
440Jim  Offline
NC
Read a couple years of posts on:
http://e85forum.com
Also check out:
http://www.raceone85.com
