Rocker Arms for Big Block #2135885
08/18/16 02:52 PM
08/18/16 02:52 PM
Berlin, Germany
Flo Offline OP
Flo  Offline OP
Berlin, Germany
hi,
in the process of planning my new big block.
-Will have std. style heads (440 source).
-hydraulic roller from Mike Jones 242/250 @.050"
.375"/.360" Lobe Lift
-rev limit at 6500rpm
-street car
What rockers to sue?
Anyone with REAL world experience? I really like the Comp steel rocker:
https://www.atechmotorsports.com/parts/cca-1621-16
but they only come in 1.5 ratio.
Has someone used the Hughes Engines 1.6 or 1.7 ratio rockers?
Any recomendations?
Greets
flo
1967 Fury III 4door HT tiny 318, late model roller block, bored and stroked to 344
Re: Rocker Arms for Big Block [Re: Flo] #2135934
08/18/16 03:53 PM
08/18/16 03:53 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've used Harland Sharps in the last two; I'm sure someone here has experience with the Hughes stuff, which as I recall are fine.
Re: Rocker Arms for Big Block [Re: Flo] #2136015
08/18/16 05:51 PM
08/18/16 05:51 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Hughes will work for your street motor but if you are getting the cryo treated ones I would just go ahead and buy the Harland sharps and never have to worry about rocker arms again....
Not knocking Hughes but buy the best and be done with it
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Rocker Arms for Big Block [Re: Flo] #2136076
08/18/16 06:56 PM
08/18/16 06:56 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
Harland Sharps, 1 and done.
Have a great day
Iowan
"obsolete is neat"
Re: Rocker Arms for Big Block [Re: Iowan] #2136091
08/18/16 07:16 PM
08/18/16 07:16 PM
IN
ahy Offline
ahy  Offline
IN
The Comp investment cast alloy steel have worked great for me on an Ed head 496. >15k miles, hammered on the road course. At freshen rockers were fine and re-used as is.
Re: Rocker Arms for Big Block [Re: Flo] #2136168
08/18/16 09:14 PM
08/18/16 09:14 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Not sure why you would spec such a mild cam, then look for 1.6 rockers. Why not use a cam that does what you want at 1.5? A deeper ratio puts more stress on the rocker gear and lifters. Not as much of an issue with a solid cam, but when coupled with a hydraulic cam is a recipe for problems in my opinion. I would advise a cam that gets you where you want to be with a 1.5 arm.
twocents
As far as advice on rocker design: for a mild build, I'd stick with a bushed steel design. Stay away from needle bearings and aluminum.
Re: Rocker Arms for Big Block [Re: ahy] #2136170
08/18/16 09:16 PM
08/18/16 09:16 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
I was wondering about this posted on the 440source customer rides page. That's a really cheap rocker, but Wade is no dummy. Hmmmmm work
9.90's@133 MPH!
over 300 runs
Wade Metzinger
Catoosa, OK
918-809-0987
71 Cuda
440 Source 440>>500 Stroker Kit
440 Source 200-1045 Aluminum Roller Rockers with .660 lift cam.
Re: Rocker Arms for Big Block [Re: Flo] #2136181
08/18/16 09:43 PM
08/18/16 09:43 PM
Idaho
LaRoy Engines Offline
Idaho
The Comp 1621 rockers work well. The least expensive aluminum rockers I would use are the Mancini Racing made by Harland sharp.
Mancini rocker arms
With Stealth heads and 1.6 rockers or 3/8 pushrods you have to grind for pushrod clearance. Even with 1.5 rockers and 5/16 pushrods you sometimes have to grind for pushrod clearance.
Re: Rocker Arms for Big Block [Re: Flo] #2136195
08/18/16 10:09 PM
08/18/16 10:09 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I have Crane golds on my source heads , 1.5 measure at 1.52:1
I am running these on a solid ft cam. Had them on since 2008 . 6-8000mls a year plus monthly bracket racing .Will reuse them on the new motor
Have to grind source heads with 1.5 and 3/8" and 5/16" pushrods
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Rocker Arms for Big Block [Re: Flo] #2136198
08/18/16 10:17 PM
08/18/16 10:17 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
If you're using the cheapo Source heads then I wouldn't waste my money on HS rockers, Comp or Crane rockers would be just fine.
Re: Rocker Arms for Big Block [Re: Flo] #2136437
08/19/16 06:37 AM
08/19/16 06:37 AM
Berlin, Germany
Flo Offline OP
Flo  Offline OP
Berlin, Germany
Well, I am using the CNCed 440source head because they look stock from the outside...
Grinding would not amtter as engine is not assembled yet.
Will stick with the Comp, just kind of sad to loose "free" valve lift.
Re: Rocker Arms for Big Block [Re: Flo] #2136450
08/19/16 08:48 AM
08/19/16 08:48 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
You're only talking a max of .600" lift on a hydraulic roller with a 1.6 rocker. Not super aggressive by any means. I think any decent brand 1.6 rocker will work with your combination. As mentioned, just keep an eye on the pushrod clearance, tip sweep, spring clearance.
[image][/image]
Re: Rocker Arms for Big Block [Re: Flo] #2136458
08/19/16 09:33 AM
08/19/16 09:33 AM
Berlin, Germany
Flo Offline OP
Flo  Offline OP
Berlin, Germany
The 1.6 rockers would nominally result in precisely .600" lift on the intake lobe. Exhaust lobe even less.
Re: Rocker Arms for Big Block [Re: Flo] #2136483
08/19/16 10:26 AM
08/19/16 10:26 AM
Berlin, Germany
Flo Offline OP
Flo  Offline OP
Berlin, Germany
The Harland Sharp are actuall less than the more fancy Hughes rockers. Are Harland Sharp the way to go?
Re: Rocker Arms for Big Block [Re: Flo] #2136621
08/19/16 02:08 PM
08/19/16 02:08 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Been running HS`s for many years and my 1.5`s actually measured 1.54 at the retainer............
Re: Rocker Arms for Big Block [Re: Flo] #2137667
08/21/16 04:30 AM
08/21/16 04:30 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use Hughes 1.6 roller tip rockers and I am very pleased with them. No problems at all and they are holding up real good on my 440/493 street combo that gets driven alot. Ron
Re: Rocker Arms for Big Block [Re: Flo] #2137761
08/21/16 11:29 AM
08/21/16 11:29 AM
USA
B3RE Offline
B3RE  Offline
USA
Real world experience? Yes.
The comp rockers are nice, but I rarely use them for the same reason you mentioned. No higher ratios. I almost always go up in ratio, and prefer a milder camshaft with a higher ratio rocker. With the better heads available these days more lift is needed to take advantage of their capabilities, but getting that lift with a 1.5 rocker means a cam that is too big For most street applications.
I would stay away from ball style adjusters on a roller rocker. Their only value is purely sentimental. I guess since the factory had them, then only true Mopar rockers would have them. Wrong!
Also, it's your money. Buy what works for your combination. Don't let others spend your money on overpriced, overhyped, or overkill parts.
And finally, whatever rocker you choose, make sure they are set up properly. Do a little research on Mopar rocker geometry. Its not about centering the roller on the valve stem. There's a lot more to it than that.
Here's a pic of 1.6s on a Big Block Mopar.
Sorry about the upside down pics. Sometimes I really hate this phone.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: Rocker Arms for Big Block [Re: Flo] #2138226
08/21/16 11:15 PM
08/21/16 11:15 PM
Cleburne,Texas
scrapmetal Offline
scrapmetal  Offline
Cleburne,Texas
I've been waiting for this Rocker arm company that went out and their employes are bring it back.They are having a hard time with their forger.I was told they are skipping them and are getting a neighbor to Cnc some .Should be out in 6 weeks.My machinist said when they were in business before that is was a good product
http://www.rockerarms.com/
Re: Rocker Arms for Big Block [Re: scrapmetal] #2138366
08/22/16 04:02 AM
08/22/16 04:02 AM
Your correct on the old company, Rocker Arm Specialitys, being sold and then going under. One of the original partners died and the other one sold it. He, Gary, took it back and got it going again as RAU and he has now resold it again is what I under stand shruggy They are making new stainless steel rockers for the older Gen 1 Chrysler and after market race motors also that use those type heads work
I do have two sets of the original ductile iron rockers that I had them blueprint, rebuild and bush and change the ratio to 1.6 on one set last year, the other set is still 1.5 ratio. I have his chromemoly steel hold downs and banana groove specail H.D. shafts also, both sets are a mix of different brands, Isky, Mopar, Crane and Ersons shruggy I would sell the 1.5 ratio set as I'm switching to the higher end race paired shaft rocker arm sets now due to that I'm using solid roller cams, more spring pressures and revving the motors to higher RPM realcrazy shruggy
Re: Rocker Arms for Big Block [Re: Flo] #2138614
08/22/16 03:07 PM
08/22/16 03:07 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
How do cup style adjusters get oiled properly?
