carpet "eyelets" #2135916
08/18/16 03:25 PM
08/18/16 03:25 PM
Social Republic of California
fc7vw9 Offline OP
fc7vw9  Offline OP
I have done some searches but no luck. Does someone make/sell the brass "eyelets" that hold the carpet in the rear corners? 70-71 e body is the application and they are oval kinda narrow.
TIA
Ron
Re: carpet "eyelets" [Re: fc7vw9] #2135946
08/18/16 04:05 PM
08/18/16 04:05 PM
Indianapolis, IN
B5Cuda440-6 Offline
B5Cuda440-6  Offline
Indianapolis, IN
I've been wondering the same thing.
There was a set of rear-carpet retainers up for sale quite some time ago, and I was wondering what years had them and how they attach.
Where are the eyelets in the carpeting?
Re: carpet "eyelets" [Re: fc7vw9] #2135954
08/18/16 04:14 PM
08/18/16 04:14 PM
fc7vw9 Offline OP
fc7vw9  Offline OP
A few of the Cudas I have had over the years (with original carpet) had them in the rear corners, there are screw on brackets that hold the carpet up in the corners, I have some originals but Ithing trying to open them with destroy them. I will try to get pictures up.
Ron
Re: carpet "eyelets" [Re: fc7vw9] #2135958
08/18/16 04:17 PM
08/18/16 04:17 PM
Indianapolis, IN
B5Cuda440-6 Offline
B5Cuda440-6  Offline
Indianapolis, IN
Pictures would be great. Thanks.
Re: carpet "eyelets" [Re: fc7vw9] #2136025
08/18/16 06:01 PM
08/18/16 06:01 PM
fc7vw9 Offline OP
fc7vw9  Offline OP
PICTURE OF ORIGINAL DRIVERS SIDE CARPET RETAINER 70 CUDA
Re: carpet "eyelets" [Re: fc7vw9] #2136026
08/18/16 06:02 PM
08/18/16 06:02 PM
fc7vw9 Offline OP
fc7vw9  Offline OP
NOTE THE "TAPE" COVERING THE LOWER WINDOW ADJUSTMENT SCREW
Re: carpet "eyelets" [Re: fc7vw9] #2136057
08/18/16 06:33 PM
08/18/16 06:33 PM
fc7vw9 Offline OP
fc7vw9  Offline OP
MY DAUGHTER SHOWED ME ETSY, THERE ARE OVAL BRASS EYELETS. JUST NEED TO CHECK SIZES.
Re: carpet "eyelets" [Re: fc7vw9] #2136153
08/18/16 08:56 PM
08/18/16 08:56 PM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
I saved this set from a 28,000 original mile 1971 Charger. There were 4. Two of them are two piece and two of them are single piece just crimped to a slice in the carpet. I usually only see the two piece type like the one I'm holding. They crimp to the carpet better...top and bottom.
Re: carpet "eyelets" [Re: fc7vw9] #2136161
08/18/16 09:04 PM
08/18/16 09:04 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
I can get those grommets (eyelets) but the installation tool is a whole different story !!!
Re: carpet "eyelets" [Re: fc7vw9] #2136193
08/18/16 10:05 PM
08/18/16 10:05 PM
Indianapolis, IN
B5Cuda440-6 Offline
B5Cuda440-6  Offline
Indianapolis, IN
Thanks for the pic, fc7vw9. Where in the picture is the carpet retainer? It is the item the wires are routed through, that is pointing down?
I've never seen one in person, so am not sure.
Re: carpet "eyelets" [Re: fc7vw9] #2136606
08/19/16 01:56 PM
08/19/16 01:56 PM
fc7vw9 Offline OP
fc7vw9  Offline OP
THESE ARE OUT OF MY 71 CUDA, THE BLACK ONE IS PLASTIC COATED AND MOUNTS TO THE DRIVERS SIDE, THE OTHER ONE IS STAMPED GALVANIZED SHEET METAL 18GA AND WAS ON THE PASS SIDE. MY 70 CUDA (LA BUILT) HAD 2 OF THE BLACK ONES, ONE ON EACH SIDE.
RON
Re: carpet "eyelets" [Re: EL5 71] #2136609
08/19/16 01:59 PM
08/19/16 01:59 PM
fc7vw9 Offline OP
fc7vw9  Offline OP
THANK YOU FOR THE PICTURES, I HAVE ONLY SEEN THE TWO PIECE SET UPS, BUT I HAVE ONLY SEEN A FEW.
RON
Re: carpet "eyelets" [Re: B5Cuda440-6] #2136628
08/19/16 02:17 PM
08/19/16 02:17 PM
Ontario, Canada
Challegator Offline
Challegator  Offline
Ontario, Canada
Does anyone have a picture of the retainers with the carpet installed? Getting close to this point of installation and you have already helped me identify what the retainers were for. up
Re: carpet "eyelets" [Re: fc7vw9] #2136651
08/19/16 02:51 PM
08/19/16 02:51 PM
Indianapolis, IN
B5Cuda440-6 Offline
B5Cuda440-6  Offline
Indianapolis, IN
Thanks for the pictures, Ron...really helpful! Now I need to track these brackets town for my LA build Cuda.
I'm also curious to see what this all looks like when assembled.
