how to remove windshield wiper arms #2133826
08/15/16 08:48 PM
08/15/16 08:48 PM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
i want to remove the transmission arms from under dash to rebuild with new gaskets etc. thanks
Re: how to remove windshield wiper arms [Re: moparpro] #2133847
08/15/16 09:03 PM
08/15/16 09:03 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Not sure what car you are working on....if a 67-70 B body you need to get under the dash on your back.....you may need to remove some other items in the way to access. good luck!
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: how to remove windshield wiper arms [Re: 70gtx440dana] #2133885
08/15/16 10:16 PM
08/15/16 10:16 PM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
69 b body,i have the speedometer dash parts out and i can see it.
Re: how to remove windshield wiper arms [Re: moparpro] #2134093
08/16/16 02:27 AM
08/16/16 02:27 AM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
My Coronet has AC and I was able to pull them with the heater box in and the gauge cluster, harness, radio and glove box liner out. As long as you have the wiper motor arm unbolted from the motor or the clip and cam removed, it's just a matter of removing the two nuts from the cowl bolts that secure either pivot housing. There's a foam seal between the hole in the cowl and the pivot body that makes them stuck in there pretty good, but a couple thumps from a rubber mallet will get em out of there all in one piece without disassembling the whole deal. I restored and reassembled mine and got it all back in with a new seal kit, easy peezy. The wiring harness will likely be your biggest battle.
I’m listening.
Re: how to remove windshield wiper arms [Re: moparpro] #2134156
08/16/16 09:17 AM
08/16/16 09:17 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I put new pivot seals in without much disassembled in a b body. Its been years ago and i recall only having the heater box out for a new core when i did the pivots.
I want my fair share
