57 dodge sierra wagon with engine and trans from 97 ram.
#2132804
08/14/16 06:17 PM
08/14/16 06:17 PM
Posts: 680 NW IL
Biggie
NW IL
Not sure where to put this so i will start here. I have a motor and trans out of a 97 sst ram. It is still fuel injected. I have developed a miss but only after it shifts into overdrive. It will miss when i lighty ste on the gas. If i put my foot into it it runs fine. I have replaced plugs, wires, throttle position sensor, fuel injectors. Only codes i get are miss fire in almost every cylinder and battery temp sensor which isnt hooked up. I have an aermotive regulator that is set for 51 psi at idle and holds steady as i increase throttle. What am i missing?
"Think of all the Ford owners who will someday want an automobile." John Dodge
57 dodge sierra wagon 03 chrysler 300m 10 dodge charger
Re: 57 dodge sierra wagon
[Re: Biggie]
#2132838
08/14/16 07:20 PM
08/14/16 07:20 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
If you have a misfire in almost all cylinders then it's something in common.
the injectors all use a common 12V to them and the computer switches the ground on the fuel side. I believe those engines had a plenum leak issue that might be something to look at too.
On the ignition side there is a lot more in common electrically.
I would look in those areas first. Cap, rotor, coil, etc.
[Re: Biggie]
#2132865
08/14/16 07:52 PM
08/14/16 07:52 PM
Posts: 680 NW IL
Biggie
NW IL
Plenum was fixed before we dropped motor in which was about 700 miles ago. I guess i will look at it again. Same with coil. I will rplace cap and rotor just to rule it out. I have a round 10" air clraner on it. Could the engine not be getting enough cold air?
[Re: Biggie]
#2132961
08/14/16 09:36 PM
08/14/16 09:36 PM
Supercuda
About to go away
About to go away
up yours
unless the filter is only 1/2" tall or packed full of dirt I doubt that is the problem.
Rereading the problem it looks like it's a high load, minimal throttle situation where it occurs, I'm sorta thinking vacuum leak somewhere. WOT is usually rich anyway, so a vacuum leak doesn't show up as easily then. Generally, I'm thinking the ignition would not be that picky.
Have you done any vacuum leak tests?
[Re: Biggie]
#2133078
08/14/16 11:10 PM
08/14/16 11:10 PM
Posts: 680 NW IL
Biggie
NW IL
Filter is like two inches tall. Never thought of vacuum. I replaced one i had to fuel regulator. Brake booster was fine but i will definitely test it. We never thought of that. Thanks!
[Re: Biggie]
#2134626
08/16/16 08:32 PM
08/16/16 08:32 PM
Posts: 680 NW IL
Biggie
NW IL
According to vacuum gauge im holding steady at just over 16 at idle. I sprayed carb cleaner at every hose end and no difference in idle. On the right side of engine i have fuel regulator and pcv valve and on left side i have brake booster and the other is plugged. Front is plugged too. Plenum looked great.
[Re: Biggie]
#2135137
08/17/16 02:43 PM
08/17/16 02:43 PM
Posts: 25,881 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Got a couple of pics for a fellow '57 Sierra owner?
[Re: Biggie]
#2135481
08/17/16 11:09 PM
08/17/16 11:09 PM
Posts: 680 NW IL
Biggie
NW IL
Not sure how from my phone
[Re: Biggie]
#2139616
08/23/16 11:13 PM
08/23/16 11:13 PM
Posts: 680 NW IL
Biggie
NW IL
Hey mods can this be moved to truck section?
